12-21-2016 07:28 AM - edited 03-17-2019 09:00 AM
Hi All,
I have an issue that might be resolvable, it might not be also!
A customer has a UC560 with CME 8.6. The customer has extensions 101 and 111 on internal phones. The UK has a non emergency number for the Police/NHS which are 101/111 also. I have tried creating the dial-peer below but it is just sending calls to the internal extension. I am sending it to the outgoing port but the PSTN provider cant handle the 9 so I need to drop it. Then it matches the 101 on its internal database so the call doesnt go external.
Is this by design and are there any creative way around it?!
dial-peer voice 106 pots
description *** Non Emergency calls ***
destination-pattern 9101
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind connect enable 8
progress_ind disconnect enable 8
port 0/3/0:15
forward-digits 3
Same dial-peer for 9111.
12-21-2016 07:42 AM
Can you post "debug voice ccapi inout" and "debug voice dialpeer"?
12-21-2016 07:46 AM
12-21-2016 07:47 AM
12-21-2016 07:52 AM
Looks like 101 call is matching dial-peer 106 and then sending the call out of the PRI:
07760: Dec 21 14:08:01.901: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8 callref = 0x00A0 Bearer Capability i = 0x8090A3 Standard = CCITT Transfer Capability = Speech Transfer Mode = Circuit Transfer Rate = 64 kbit/s Channel ID i = 0xA98395 Exclusive, Channel 21 Progress Ind i = 0x8183 - Origination address is non-ISDN Calling Party Number i = 0x0180, '131' Plan:ISDN, Type:Unknown Called Party Number i = 0x81, '101' Plan:ISDN, Type:Unknown 007761: Dec 21 14:08:02.089: ISDN Se0/3/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x80A0 Channel ID i = 0xA98395 Exclusive, Channel 21
And then disconnects about 4-5 seconds later. So, all seems fine here. When does the phone with DN 101 begin to ring? Immediately or 4-5 seconds later?
12-21-2016 07:55 AM
Hi Chris, it rings immediately but then we hung up a few seconds later. The customer stated that it was ringing on the internal extension not going out.
12-21-2016 07:43 AM
Create a translation rule and apply it to the port:
voice translation-rule 1
rule 1 /^9101$/ /101/
voice translation-profile profile1
translate called 1
translation-profile outgoing profile1
Remove forward-digits 3 command from the dial peer
Brandon
