03-19-2008 10:58 PM - edited 03-15-2019 09:33 AM
receiving error when attempting csim. Trying to configure router for SRST and calls not completing...
csim: called number = 912816740702, loop count = 1 ping count = 0
csim err:csim_do_test invalid major major(16) minor(0)
csim: loop = 1, failed = 0
csim: call attempted = 1, setup failed = 0, tone failed = 0
03-20-2008 01:54 AM
Hi, is this an H.323 or MGCP gateway?
If MGCP the CSIM command won't work as callmanager is in control. What dial-peers have you got configured for SRST?
03-20-2008 07:09 PM
What type of dial-peers voip or pots?
DO you have examples of your dial-peers
03-21-2008 07:49 AM
This is an MGCP gateway, however, the dial-peers are being tested during SRST operation. AN example of a dial-peer is:
dial-peer voice 41 pots
tone ringback alert-no-PI
description Outbound Toll-International Calls
destination-pattern 801+
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
clid network-number 2766797020
port 1/0/0
forward-digits extra
prefix 011
Mike
