12-31-2014 05:35 AM - edited 03-17-2019 01:27 AM
Hi ALL,
I an UC540 have a dial-peer defined like this:
dial-peer voice 1500 voip description ** Outgoing CallBrokerCC SIP gateway ** destination-pattern [*]?3..$ session protocol sipv2 session target ipv4:192.168.x.x voice-class codec 1 voice-class sip dtmf-relay force rtp-nte dtmf-relay rtp-nte no vad
Question mark in destination-pattern is entered owith CTRL-V before.
The dialplan seems to be working as shown below but the thing is *3xx is not being matched when actually dialed from a phone. OTOH, 3xx numbers match with no problem at all.
show dialplan number *350
Macro Exp.: *350
VoiceOverIpPeer1500
peer type = voice, system default peer = FALSE, information type = voice,
description = `** Outgoing CallBrokerCC SIP gateway **',
tag = 1500, destination-pattern = `[*]?3..$',
voice reg type = 0, corresponding tag = 0,
allow watch = FALSE
answer-address = `', preference=0,
CLID Restriction = None
CLID Network Number = `'
CLID Second Number sent
CLID Override RDNIS = disabled,
rtp-ssrc mux = system
source carrier-id = `', target carrier-id = `',
source trunk-group-label = `', target trunk-group-label = `',
numbering Type = `unknown'
group = 1500, Admin state is up, Operation state is up,
incoming called-number = `', connections/maximum = 0/unlimited,
DTMF Relay = enabled,
modem transport = system,
URI classes:
Incoming (Request) =
Incoming (Via) =
Incoming (To) =
Incoming (From) =
Destination =
huntstop = disabled,
in bound application associated: 'DEFAULT'
out bound application associated: ''
dnis-map =
permission :both
incoming COR list:maximum capability
outgoing COR list:call-national
outgoing LPCOR:
Translation profile (Incoming):
Translation profile (Outgoing):
incoming call blocking:
translation-profile = `'
disconnect-cause = `no-service'
advertise 0x40 capacity_update_timer 25 addrFamily 0 oldAddrFamily 0
mailbox selection policy: none
type = voip, session-target = `ipv4:192.168.x.x',
technology prefix:
settle-call = disabled
ip media DSCP = ef, ip media rsvp-pass DSCP = ef
ip media rsvp-fail DSCP = ef, ip signaling DSCP = af31,
ip video rsvp-none DSCP = af41,ip video rsvp-pass DSCP = af41
ip video rsvp-fail DSCP = af41,
ip defending Priority = 0, ip preemption priority = 0
ip policy locator voice:
ip policy locator video:
UDP checksum = disabled,
session-protocol = sipv2, session-transport = system,
req-qos = best-effort, acc-qos = best-effort,
req-qos video = best-effort, acc-qos video = best-effort,
req-qos audio def bandwidth = 64, req-qos audio max bandwidth = 0,
req-qos video def bandwidth = 384, req-qos video max bandwidth = 0,
dtmf-relay = rtp-nte,
RTP dynamic payload type values: NTE = 101
Cisco: NSE=100, fax=96, fax-ack=97, dtmf=121, fax-relay=122
CAS=123, TTY=119, ClearChan=125, PCM switch over u-law=0,
A-law=8, GSMAMR-NB=117 iLBC=116, AAC-ld=114, iSAC=124
lmr_tone=0, nte_tone=0
h263+=118, h264=119
G726r16 using static payload
G726r24 using static payload
RTP comfort noise payload type = 19
fax rate = voice, payload size = 20 bytes
fax protocol = system
fax-relay ecm enable
Fax Relay ans treatment disabled
Fax Relay ans enabled
Fax Relay SG3-to-G3 Enabled (by system configuration)
fax NSF = 0xAD0051 (default)
voice-class codec = 1
codec = g729r8, payload size = 20 bytes,
video codec = None
voice class codec = 1
voice class sip session refresh system
voice class sip rsvp-fail-policy voice post-alert mandatory keep-alive interval 30
voice class sip rsvp-fail-policy voice post-alert optional keep-alive interval 30
voice class sip rsvp-fail-policy video post-alert mandatory keep-alive interval 30
voice class sip rsvp-fail-policy video post-alert optional keep-alive interval 30
text relay = disabled
Media Setting = forking (disabled) flow-through (global)
Expect factor = 10, Icpif = 20,
Playout Mode is set to adaptive,
Initial 60 ms, Max 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Fax nominal 300 ms
Max Redirects = 1, signaling-type = cas,
VAD = disabled, Poor QOV Trap = disabled,
Source Interface = NONE
voice class sip url = system,
voice class sip tel-config url = system,
voice class sip rel1xx = system,
voice class sip anat = system,
voice class sip outbound-proxy = "system",
voice class sip associate registered-number =
system,
voice class sip asserted-id system,
voice class sip privacy system
voice class sip e911 = system,
voice class sip history-info = system,
voice class sip reset timer expires 183 = system,
voice class sip pass-thru headers = system,
voice class sip pass-thru content unsupp = system,
voice class sip pass-thru content sdp = system,
voice class sip copy-list = system,
voice class sip g729 annexb-all = system,
voice class sip early-offer forced = system,
voice calss sip delay-offer forced = disable,
voice class sip negotiate cisco = system,
voice class sip block 180 = system,
voice class sip block 183 = system,
voice class sip block 181 = system,
voice class sip preloaded-route = system,
voice class sip random-contact = system,
voice class sip random-request-uri validate = system,
voice class sip call-route p-called-party-id = system,
voice class sip call-route history-info = system,
voice class sip privacy-policy send-always = system,
voice class sip privacy-policy passthru = system,
voice class sip privacy-policy strip history-info = system,
voice class sip privacy-policy strip diversion = system,
voice class sip map resp-code 181 = system,
voice class sip bind control = system,
voice class sip bind media = system,
voice class sip bandwidth audio = system,
voice class sip bandwidth video = system,
voice class sip encap clear-channel = system,
voice class sip error-code-override options-keepalive failure = system,
voice class sip calltype-video = false
voice class sip registration passthrough = System
voice class sip authenticate redirecting-number = system,
redirect ip2ip = disabled
local peer = false
probe disabled,
Secure RTP: system (use the global setting)
voice class perm tag = `'
Time elapsed since last clearing of voice call statistics never
Connect Time = 18641, Charged Units = 0,
Successful Calls = 19, Failed Calls = 4, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "10 ",
Last Disconnect Text is "normal call clearing (16)",
Last Setup Time = 7553673.
Last Disconnect Time = 7553992.
Matched: *350 Digits: 3
Target: ipv4:192.168.x.x
What could be causing this? any ideas?
Thanks in advance!
12-31-2014 07:47 AM
So what DP is actually being matched when you dial? I believe the show dialplan uses enbloc and not digit by digit so this could be affecting how it is being routed versus your tests via CLI. Can you provide a debug and all possible DP matches?
12-31-2014 09:02 AM
Many thanks for your answer.
This is on a remote client location and I won't be able to get anyone to check untill 02/01. In the meantime what output be suitable? Maybe
debug voip ccapi inout debug ccsip messages
I'll come back with output for these and any others you may suggest for both 350 and *350 cases.
12-31-2014 09:38 AM
I would add debug voice dialpeer all.
01-02-2015 02:36 AM
Thanks, I'm sending those in the main reply.
12-31-2014 09:47 AM
ccapi is the only relevant one at this point since we haven't even got to the SIP signalling yet. CCAPI inout will show dialpeer selection as the keys are pressed.
01-02-2015 02:56 AM
OK, I'm back with promised logs.
As far as I cant tell, the phone is not actually sending any digits when dialing starts with "*", This is an SPA-301 phone. Does that make any sense?
The intent of this destination-pattern is to match any 3 digit number begining with 3 and possibly prefixed with *; hence both 350 and *350 should match.
Here is log output with both 350 and *350. I'm probably misinterpreting them :-)
OUTPUT: debug voice ccapi inout, dialed num 350: 010362: //-1/38F9193B821D/CCAPI/cc_api_display_ie_subfields: cc_api_call_setup_ind_common: cisco-username= ----- ccCallInfo IE subfields ----- cisco-ani=203 cisco-anitype=0 cisco-aniplan=0 cisco-anipi=0 cisco-anisi=0 dest= cisco-desttype=0 cisco-destplan=0 cisco-rdie=FFFFFFFF cisco-rdn= cisco-rdntype=0 cisco-rdnplan=0 cisco-rdnpi=0 cisco-rdnsi=0 cisco-redirectreason=0 fwd_final_type =0 final_redirectNumber = hunt_group_timeout =0 010363: //-1/38F9193B821D/CCAPI/cc_api_call_setup_ind_common: Interface=0x8965FB98, Call Info( Calling Number=203,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Incoming Dial-peer=20042, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE, Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1 010364: //-1/38F9193B821D/CCAPI/ccCheckClipClir: In: Calling Number=203(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) 010365: //-1/38F9193B821D/CCAPI/ccCheckClipClir: Out: Calling Number=203(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) 010366: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 010367: :cc_get_feature_vsa malloc success 010368: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 010369: cc_get_feature_vsa count is 5 010370: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 010371: :FEATURE_VSA attributes are: feature_name:0,feature_time:2337650040,feature_id:211 010372: //178/38F9193B821D/CCAPI/cc_api_call_setup_ind_common: Set Up Event Sent; Call Info(Calling Number=203(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=(TON=Unknown, NPI=Unknown)) 010373: //178/38F9193B821D/CCAPI/cc_process_call_setup_ind: Event=0x885D4310 010374: //178/38F9193B821D/CCAPI/ccCallSetContext: Context=0x8B97533C 010375: //178/38F9193B821D/CCAPI/cc_process_call_setup_ind: >>>>CCAPI handed cid 178 with tag 20042 to app "_ManagedAppProcess_Default" 010376: //178/38F9193B821D/CCAPI/ccCallSetupAck: Call Id=178 010377: //178/38F9193B821D/CCAPI/cc_api_set_transfer_info: Transfer Number=, Transfer Reason=0x0 010378: //178/38F9193B821D/CCAPI/ccGenerateToneInfo: Stop Tone On Digit=TRUE, Tone=Dial Tone, Tone Direction=Network, Params=0x0, Call Id=178 010379: //178/38F9193B821D/CCAPI/ccSetDigitTimeouts: Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms) 010380: //178/38F9193B821D/CCAPI/ccSetDigitTimeouts: Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms)) 010381: //178/38F9193B821D/CCAPI/ccCallReportDigits: (callID=0xB2, digit_event=0x1, enable=TRUE, consume=FALSE) 010382: //178/38F9193B821D/CCAPI/ccCallReportDigits: Enabled=TRUE, Call Id=178 010383: //178/38F9193B821D/CCAPI/cc_api_call_report_digits_done: (vdbPtr=0x8965FB98, callID=0xB2, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE) 010384: //178/38F9193B821D/CCAPI/cc_api_call_report_digits_done: Enabled=TRUE, Disposition=0x0, Interface=0x8965FB98, Call Id=178 010385: //178/38F9193B821D/CCAPI/cc_api_call_report_digits_done: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=20000(ms)) 010386: //178/38F9193B821D/CCAPI/cc_api_call_digit_begin: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1, Source Call Id=178, Digit=3, DigitBeginFlags=0x0, Rtp Timestamp=0x6570C0, Rtp Expiration=0x0 010387: //178/38F9193B821D/CCAPI/cc_api_call_digit_end: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1, Source Call Id=178, Digit=3, Duration=100, Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF 010388: //178/38F9193B821D/CCAPI/cc_api_call_digit_end: Call Entry(Handoff Depth=0) 010389: //178/38F9193B821D/CCAPI/cc_api_call_digit_begin: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1, Source Call Id=178, Digit=5, DigitBeginFlags=0x0, Rtp Timestamp=0x65EDC0, Rtp Expiration=0x0 010390: //178/38F9193B821D/CCAPI/cc_api_call_digit_end: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1, Source Call Id=178, Digit=5, Duration=100, Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF 010391: //178/38F9193B821D/CCAPI/cc_api_call_digit_end: Call Entry(Handoff Depth=0) 010392: //178/38F9193B821D/CCAPI/cc_api_call_digit_begin: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1, Source Call Id=178, Digit=0, DigitBeginFlags=0x0, Rtp Timestamp=0x666AC0, Rtp Expiration=0x0 010393: //178/38F9193B821D/CCAPI/cc_api_call_digit_end: Destination Interface=0x0, Destination Mask=0x3, Destination Call Id=-1, Source Call Id=178, Digit=0, Duration=100, Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF 010394: //178/38F9193B821D/CCAPI/cc_api_call_digit_end: Call Entry(Handoff Depth=0) 010395: //178/38F9193B821D/CCAPI/ccCallReportDigits: (callID=0xB2, digit_event=0x0, enable=FALSE, consume=FALSE) 010396: //178/38F9193B821D/CCAPI/ccCallReportDigits: Enabled=TRUE, Call Id=178 010397: //178/38F9193B821D/CCAPI/cc_api_call_report_digits_done: (vdbPtr=0x8965FB98, callID=0xB2, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE) 010398: //178/38F9193B821D/CCAPI/cc_api_call_report_digits_done: Enabled=TRUE, Disposition=0x0, Interface=0x8965FB98, Call Id=178 010399: //178/38F9193B821D/CCAPI/cc_api_call_report_digits_done: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=20000(ms)) 010400: //178/38F9193B821D/CCAPI/ccCallProceeding: Progress Indication=NULL(0) 010401: //178/38F9193B821D/CCAPI/ccCallSetupRequest: Destination=, Calling IE Present=TRUE, Mode=0, Outgoing Dial-peer=1500, Params=0x8B972A0C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3) 010402: //178/38F9193B821D/CCAPI/ccCheckClipClir: In: Calling Number=203(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) 010403: //178/38F9193B821D/CCAPI/ccCheckClipClir: Out: Calling Number=203(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) 010404: //178/38F9193B821D/CCAPI/ccCallSetupRequest: Destination Pattern=[*]?3..$, Called Number=350, Digit Strip=FALSE 010405: //178/38F9193B821D/CCAPI/ccCallSetupRequest: Calling Number=203(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=350(TON=Unknown, NPI=Unknown), Redirect Number=, Display Info=TAMARIZ TELKO Account Number=, Final Destination Flag=FALSE, Guid=38F9193B-919E-11E4-821D-8497398FBEF0, Outgoing Dial-peer=1500 010406: //178/38F9193B821D/CCAPI/cc_api_display_ie_subfields: ccCallSetupRequest: cisco-username= ----- ccCallInfo IE subfields ----- cisco-ani=203 cisco-anitype=0 cisco-aniplan=0 cisco-anipi=0 cisco-anisi=0 dest=350 cisco-desttype=0 cisco-destplan=0 cisco-rdie=FFFFFFFF cisco-rdn= cisco-rdntype=0 cisco-rdnplan=0 cisco-rdnpi=0 cisco-rdnsi=0 cisco-redirectreason=0 fwd_final_type =0 final_redirectNumber = hunt_group_timeout =0 010407: //178/38F9193B821D/CCAPI/ccIFCallSetupRequestPrivate: Interface=0x88064440, Interface Type=3, Destination=, Mode=0x0, Call Params(Calling Number=203,(Calling Name=TAMARIZ TELKO)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=350(TON=Unknown, NPI=Unknown), Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=1500, Call Count On=FALSE, Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=) 010408: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 010409: :cc_get_feature_vsa malloc success 010410: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 010411: cc_get_feature_vsa count is 6 010412: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 010413: :FEATURE_VSA attributes are: feature_name:0,feature_time:2337649816,feature_id:212 010414: //179/38F9193B821D/CCAPI/ccIFCallSetupRequestPrivate: SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1 010415: //179/38F9193B821D/CCAPI/ccCallSetContext: Context=0x8B9729BC 010416: //178/38F9193B821D/CCAPI/ccSaveDialpeerTag: Outgoing Dial-peer=1500 010417: //179/38F9193B821D/CCAPI/cc_api_call_proceeding: Interface=0x88064440, Progress Indication=NULL(0) 010418: //179/38F9193B821D/CCAPI/cc_api_call_connected: Interface=0x88064440, Data Bitmask=0x1, Progress Indication=NULL(0), Connection Handle=0 010419: //179/38F9193B821D/CCAPI/cc_api_call_connected: Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0) 010420: //178/38F9193B821D/CCAPI/ccConferenceCreate: (confID=0x87E8018C, callID1=0xB2, gcid=38F9193B-919E11E4-821D8497-398FBEF0, tag=0x0) 010421: //179/38F9193B821D/CCAPI/ccConferenceCreate: (confID=0x87E8018C, callID2=0xB3, gcid=38F9193B-919E11E4-821D8497-398FBEF0, tag=0x0) 010422: //178/38F9193B821D/CCAPI/ccConferenceCreate: Conference Id=0x87E8018C, Call Id1=178, Call Id2=179, Tag=0x0 010423: //178/38F9193B821D/CCAPI/cc_api_bridge_done: Conference Id=0x29, Source Interface=0x8965FB98, Source Call Id=178, Destination Call Id=179, Disposition=0x0, Tag=0xFFFFFFFF 010424: //179/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream: 010425: cc_api_get_xcode_stream : 4702 010426: //179/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream: 010427: cc_api_get_xcode_stream : 4702 010428: //179/38F9193B821D/CCAPI/cc_api_bridge_done: Conference Id=0x29, Source Interface=0x88064440, Source Call Id=179, Destination Call Id=178, Disposition=0x0, Tag=0x0 010429: //178/38F9193B821D/CCAPI/cc_generic_bridge_done: Conference Id=0x29, Source Interface=0x88064440, Source Call Id=179, Destination Call Id=178, Disposition=0x0, Tag=0x0 010430: //178/38F9193B821D/CCAPI/ccConferenceCreate: Call Entry(Conference Id=0x29, Destination Call Id=179) 010431: //179/38F9193B821D/CCAPI/ccConferenceCreate: Call Entry(Conference Id=0x29, Destination Call Id=178) 010432: //178/38F9193B821D/CCAPI/cc_api_caps_ind: Destination Interface=0x88064440, Destination Call Id=179, Source Call Id=178, Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1, Modem=0x0, Codec Bytes=20, Signal Type=3) 010433: //178/38F9193B821D/CCAPI/cc_api_caps_ind: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms), Playout Max=1000(ms), Fax Nom=300(ms)) 010434: //179/38F9193B821D/CCAPI/cc_api_caps_ind: Destination Interface=0x8965FB98, Destination Call Id=178, Source Call Id=179, Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1, Modem=0x0, Codec Bytes=160, Signal Type=2) 010435: //179/38F9193B821D/CCAPI/cc_api_caps_ind: Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms), Playout Max=1000(ms), Fax Nom=300(ms)) 010436: //179/38F9193B821D/CCAPI/cc_api_caps_ack: Destination Interface=0x8965FB98, Destination Call Id=178, Source Call Id=179, Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1), Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9375) 010437: //178/38F9193B821D/CCAPI/cc_api_caps_ack: Destination Interface=0x88064440, Destination Call Id=179, Source Call Id=178, Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1), Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9375) 010438: //178/38F9193B821D/CCAPI/ccCallConnect: Progress Indication=NULL(0), Data Bitmask=0x1 010439: //178/38F9193B821D/CCAPI/ccCallConnect: Call Entry(Connected=TRUE, Responsed=TRUE) 010440: //178/38F9193B821D/CCAPI/ccCallFeature: Feature Type=25, Call Id=178 010441: //178/38F9193B821D/CCAPI/cc_process_notify_bridge_done: Conference Id=0x29, Call Id1=178, Call Id2=179 010442: //178/38F9193B821D/CCAPI/cc_api_voice_mode_event: Call Id=178 010443: //178/38F9193B821D/CCAPI/cc_api_voice_mode_event: Call Entry(Context=0x8B97533C) 010444: //178/38F9193B821D/CCAPI/cc_api_call_disconnected: Cause Value=16, Interface=0x8965FB98, Call Id=178 010445: //178/38F9193B821D/CCAPI/cc_api_call_disconnected: Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0) 010446: //178/38F9193B821D/CCAPI/ccConferenceDestroy: Conference Id=0x29, Tag=0x0 010447: //178/38F9193B821D/CCAPI/cc_api_bridge_drop_done: Conference Id=0x29, Source Interface=0x8965FB98, Source Call Id=178, Destination Call Id=179, Disposition=0x0, Tag=0x0 010448: //179/38F9193B821D/CCAPI/cc_api_bridge_drop_done: Conference Id=0x29, Source Interface=0x88064440, Source Call Id=179, Destination Call Id=178, Disposition=0x0, Tag=0x0 010449: //178/38F9193B821D/CCAPI/cc_generic_bridge_done: Conference Id=0x29, Source Interface=0x88064440, Source Call Id=179, Destination Call Id=178, Disposition=0x0, Tag=0x0 010450: //178/38F9193B821D/CCAPI/ccCallDisconnect: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16) 010451: //178/38F9193B821D/CCAPI/ccCallDisconnect: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16) 010452: //178/38F9193B821D/CCAPI/cc_api_get_transfer_info: Transfer Number Is Null 010453: //179/38F9193B821D/CCAPI/ccCallDisconnect: Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0) 010454: //179/38F9193B821D/CCAPI/ccCallDisconnect: Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16) 010455: //178/38F9193B821D/CCAPI/cc_api_call_feature: Feature Type=6, Interface=0x8965FB98, Call Id=178 010456: //178/38F9193B821D/CCAPI/cc_api_call_disconnect_done: Disposition=0, Interface=0x8965FB98, Tag=0x0, Call Id=178, Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0) 010457: //178/38F9193B821D/CCAPI/cc_api_call_disconnect_done: Call Disconnect Event Sent 010458: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: 010459: :cc_free_feature_vsa freeing 8B55B570 010460: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: 010461: vsacount in free is 5 010462: //179/38F9193B821D/CCAPI/cc_api_call_disconnect_done: Disposition=0, Interface=0x88064440, Tag=0x0, Call Id=179, Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0) 010463: //179/38F9193B821D/CCAPI/cc_api_call_disconnect_done: Call Disconnect Event Sent 010464: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: 010465: :cc_free_feature_vsa freeing 8B55B490 010466: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: 010467: vsacount in free is 4
OUTPUT: debug voice ccapi inout, dialed num 350: 010468: //-1/6D9A66738223/CCAPI/cc_api_display_ie_subfields: cc_api_call_setup_ind_common: cisco-username= ----- ccCallInfo IE subfields ----- cisco-ani=203 cisco-anitype=0 cisco-aniplan=0 cisco-anipi=0 cisco-anisi=0 dest= cisco-desttype=0 cisco-destplan=0 cisco-rdie=FFFFFFFF cisco-rdn= cisco-rdntype=0 cisco-rdnplan=0 cisco-rdnpi=0 cisco-rdnsi=0 cisco-redirectreason=0 fwd_final_type =0 final_redirectNumber = hunt_group_timeout =0 010469: //-1/6D9A66738223/CCAPI/cc_api_call_setup_ind_common: Interface=0x8965FB98, Call Info( Calling Number=203,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Incoming Dial-peer=20042, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE, Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1 010470: //-1/6D9A66738223/CCAPI/ccCheckClipClir: In: Calling Number=203(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) 010471: //-1/6D9A66738223/CCAPI/ccCheckClipClir: Out: Calling Number=203(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) 010472: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 010473: :cc_get_feature_vsa malloc success 010474: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 010475: cc_get_feature_vsa count is 5 010476: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 010477: :FEATURE_VSA attributes are: feature_name:0,feature_time:2337649816,feature_id:213 010478: //180/6D9A66738223/CCAPI/cc_api_call_setup_ind_common: Set Up Event Sent; Call Info(Calling Number=203(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=(TON=Unknown, NPI=Unknown)) 010479: //180/6D9A66738223/CCAPI/cc_process_call_setup_ind: Event=0x885D4310 010480: //180/6D9A66738223/CCAPI/ccCallSetContext: Context=0x8B96D6BC 010481: //180/6D9A66738223/CCAPI/cc_process_call_setup_ind: >>>>CCAPI handed cid 180 with tag 20042 to app "_ManagedAppProcess_Default" 010482: //180/6D9A66738223/CCAPI/ccCallSetupAck: Call Id=180 010483: //180/6D9A66738223/CCAPI/cc_api_set_transfer_info: Transfer Number=, Transfer Reason=0x0 010484: //180/6D9A66738223/CCAPI/ccGenerateToneInfo: Stop Tone On Digit=TRUE, Tone=Dial Tone, Tone Direction=Network, Params=0x0, Call Id=180 010485: //180/6D9A66738223/CCAPI/ccSetDigitTimeouts: Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms) 010486: //180/6D9A66738223/CCAPI/ccSetDigitTimeouts: Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms)) 010487: //180/6D9A66738223/CCAPI/ccCallReportDigits: (callID=0xB4, digit_event=0x1, enable=TRUE, consume=FALSE) 010488: //180/6D9A66738223/CCAPI/ccCallReportDigits: Enabled=TRUE, Call Id=180 010489: //180/6D9A66738223/CCAPI/cc_api_call_report_digits_done: (vdbPtr=0x8965FB98, callID=0xB4, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE) 010490: //180/6D9A66738223/CCAPI/cc_api_call_report_digits_done: Enabled=TRUE, Disposition=0x0, Interface=0x8965FB98, Call Id=180 010491: //180/6D9A66738223/CCAPI/cc_api_call_report_digits_done: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=20000(ms)) 010492: //180/6D9A66738223/CCAPI/cc_handle_inter_digit_timer: Generate inter-digit timeout CC_EV_CALL_DIGIT_END event 010493: //180/6D9A66738223/CCAPI/ccCallReportDigits: (callID=0xB4, digit_event=0x0, enable=FALSE, consume=FALSE) 010494: //180/6D9A66738223/CCAPI/ccCallReportDigits: Enabled=TRUE, Call Id=180 010495: //180/6D9A66738223/CCAPI/cc_api_call_report_digits_done: (vdbPtr=0x8965FB98, callID=0xB4, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE) 010496: //180/6D9A66738223/CCAPI/cc_api_call_report_digits_done: Enabled=TRUE, Disposition=0x0, Interface=0x8965FB98, Call Id=180 010497: //180/6D9A66738223/CCAPI/cc_api_call_report_digits_done: Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=20000(ms)) 010498: //180/6D9A66738223/CCAPI/ccCallDisconnect: Cause Value=28, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0) 010499: //180/6D9A66738223/CCAPI/ccCallDisconnect: Cause Value=28, Call Entry(Responsed=TRUE, Cause Value=28) 010500: //180/6D9A66738223/CCAPI/cc_api_get_transfer_info: Transfer Number Is Null 010501: //180/6D9A66738223/CCAPI/cc_api_call_disconnect_done: Disposition=0, Interface=0x8965FB98, Tag=0x0, Call Id=180, Call Entry(Disconnect Cause=28, Voice Class Cause Code=0, Retry Count=0) 010502: //180/6D9A66738223/CCAPI/cc_api_call_disconnect_done: Call Disconnect Event Sent 010503: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: 010504: :cc_free_feature_vsa freeing 8B55B490 010505: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa: 010506: vsacount in free is 4
OUTPUT: debug voice dialpeer all, dialed num 350:
010507: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=203, Called Number=, Voice-Interface=0x8965FB98,
Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
010508: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=203
010509: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
010510: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=203T
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
010511: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
010512: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
010513: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=203
010514: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
010515: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
010516: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=20042 Is Matched
010517: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
010518: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20042
010519: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
010520: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6564
010521: //-1/E028D9A38227/DPM/dpMatchPeersCore:
Calling Number=, Called Number=3, Peer Info Type=DIALPEER_INFO_SPEECH
010522: //-1/E028D9A38227/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=3
010523: //-1/E028D9A38227/DPM/dpMatchCore:
Dial String=3, Expanded String=3, Calling Number=
Timeout=FALSE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
010524: //-1/E028D9A38227/DPM/MatchNextPeer:
Result=MORE_DIGITS_NEEDED(1); Outgoing Dial-peer=1500
010525: //-1/E028D9A38227/DPM/dpMatchCore:
Result=1
010526: //-1/E028D9A38227/DPM/dpMatchPeersCore:
Result=Partial Matches(1) after DP_MATCH_DEST
010527: //-1/E028D9A38227/DPM/dpMatchSafModulePlugin:
dialstring=3, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
010528: //-1/E028D9A38227/DPM/dpMatchPeersMoreArg:
010529: //-1/E028D9A38227/DPM/dpMatchPeersCore:
Calling Number=, Called Number=35, Peer Info Type=DIALPEER_INFO_SPEECH
010530: //-1/E028D9A38227/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=35
010531: //-1/E028D9A38227/DPM/dpMatchCore:
Dial String=35, Expanded String=35, Calling Number=
010532: //-1/E028D9A38227/DPM/MatchNextPeer:
010533: //-1/E028D9A38227/DPM/dpMatchCore:
Result=1
010534: //-1/E028D9A38227/DPM/dpMatchPeersCore:
010535: //-1/E028D9A38227/DPM/dpMatchSafModulePlugin:
dialstring=35, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
010536: //-1/E028D9A38227/DPM/dpMatchPeersMoreArg:
010537: //-1/E028D9A38227/DPM/dpMatchPeersCore:
Calling Number=, Called Number=350, Peer Info Type=DIALPEER_INFO_SPEECH
010538: //-1/E028D9A38227/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=350
010539: //-1/E028D9A38227/DPM/dpMatchCore:
Dial String=350, Expanded String=350, Calling Number=
010540: //-1/E028D9A38227/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=1500 Is Matched
010541: //-1/E028D9A38227/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
010542: //-1/E028D9A38227/DPM/dpMatchSafModulePlugin:
dialstring=350, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
010543: //-1/E028D9A38227/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=1500
010544: //-1/E028D9A38227/DPM/dpMatchPeersCore:
010545: //-1/E028D9A38227/DPM/dpMatchPeersCore:
010546: //-1/E028D9A38227/DPM/dpMatchCore:
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
010547: //-1/E028D9A38227/DPM/MatchNextPeer:
010548: //-1/E028D9A38227/DPM/dpMatchPeersCore:
010549: //-1/E028D9A38227/DPM/dpMatchSafModulePlugin:
dialstring=350, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
010550: //-1/E028D9A38227/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
010551: //-1/E028D9A38227/DPM/dpMatchPeersCore:
010552: //-1/E028D9A38227/DPM/dpMatchPeersCore:
010553: //-1/E028D9A38227/DPM/dpMatchCore:
010554: //-1/E028D9A38227/DPM/MatchNextPeer:
010555: //-1/E028D9A38227/DPM/dpMatchPeersCore:
010556: //-1/E028D9A38227/DPM/dpMatchSafModulePlugin:
010557: //-1/E028D9A38227/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
010558: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=350, Called Number=350, Peer Info Type=DIALPEER_INFO_SPEECH
010559: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010560: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=350, Expanded String=350, Calling Number=350T
010561: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
010562: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010563: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
010564: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
010565: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
010566: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=NO_MATCH(-1) After All Match Rules Attempt
010567: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
010568: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
010569: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=350, Called Number=, Voice-Interface=0x0,
010570: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ANSWER; Calling Number=350
010571: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
010572: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=350T
010573: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
010574: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
010575: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_ORIGINATE; Calling Number=350
010576: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
010577: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
010578: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=1500 Is Matched
010579: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
010580: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=1500
010581: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
010582: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6613
010583: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010584: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010585: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
010586: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
010587: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010588: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
010589: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
010590: //-1/E028D9A38227/DPM/dpMatchPeersCore:
010591: //-1/E028D9A38227/DPM/dpMatchPeersCore:
010592: //-1/E028D9A38227/DPM/dpMatchCore:
010593: //-1/E028D9A38227/DPM/MatchNextPeer:
010594: //-1/E028D9A38227/DPM/dpMatchPeersCore:
010595: //-1/E028D9A38227/DPM/dpMatchSafModulePlugin:
dialstring=350, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
010596: //-1/E028D9A38227/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
010597: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010598: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010599: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
010600: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
010601: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010602: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
010603: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
010604: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010605: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010606: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
010607: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
010608: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010609: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
010610: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
010611: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=, Called Number=203, Peer Info Type=DIALPEER_INFO_SPEECH
010612: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=203
010613: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=203, Expanded String=203, Calling Number=
010614: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=20042 Is Matched
010615: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010616: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
010617: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
1: Dial-peer Tag=20042
010618: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010619: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010620: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
010621: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
010622: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010623: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
010624: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
Result=SUCCESS(0)
010625: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010626: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010627: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
010628: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
010629: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010630: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
010631: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
010632: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010633: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010634: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
010635: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
010636: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010637: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
010638: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
010639: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010640: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010641: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
010642: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
010643: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
010644: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
010645: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
OUTPUT: debug voice dialpeer all, dialed num *350:
010646: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
010647: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
010648: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
010649: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
010650: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
010651: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
010652: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
010653: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
010654: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
010655: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
010656: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5985
010657: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
010658: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
010659: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6564
01-02-2015 06:35 AM
So when you dial, * isn't being picked up as a literal string and the gateway is just sending 350 then thus the output of the debugs?
01-02-2015 11:11 AM
I'm a bit out of my water here but I'd say when * is dialed nothing is being actually sent to the DP selection code. Then, when the inter-digit timeout hits the call gets disconnected and I get a busy tone.
Could it be Feature Access Code which is interfering here? IOW, could *350 be being interpreted as an invalid FAC? How'd I confirm that?
01-02-2015 11:16 AM
You would hear an audible tone if CAC/FAC was using that code. Do you just have a UC540 or a CUCM to go with it as well?
01-02-2015 03:31 PM
You should see it. Granted I just tested with CUCM. But I do see the * being sent to the gateway. Here is the output from mine.
10065046: Jan 2 16:07:20: //-1/191609800052/CCAPI/cc_api_display_ie_subfields:
cisco-username=9712448996
cisco-ani=sip:97124XXXXX@10.38.246.XXX
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=sip:*15124XXXXXX@10.35.118.XXX:5060
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
10065047: Jan 2 16:07:20: //-1/191609800052/CCAPI/cc_api_call_setup_ind_common:
Interface=0x254772D0, Call Info(
Calling Number=sip:971244XXXX@10.38.246.XXX,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=sip:*1512XXXXXX@10.35.118.XXX:5060(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=6002, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=2477522
10065048: Jan 2 16:07:20: //-1/191609800052/CCAPI/ccCheckClipClir:
In: Calling Number=sip:97124XXXXX@10.38.246.XXX(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
I don't have a 540 to test with. But can you make sure under the dial plan you don't have anything that is discarding it?
01-19-2015 01:32 AM
Hi All,
Just comming back to report. This was the phones speed dial feature preventing dialed digits to be actually sent over. Customer didn't use speed dial but didn't want it disabled.
Finally got my provider to modify its product to take postfix asterisks instead o prefix.
Thanks everyone for your support
