10-05-2012 02:42 AM - edited 03-16-2019 01:32 PM
Hi guys,
does anyone know how the following dial peers are matched?
dial-peer voice 1 pots
destination-pattern 22
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 pots
direct-inward-dial
port 0/0/1:15
Thanks.
Solved! Go to Solution.
10-05-2012 03:07 AM
DPs of same preference will distribute calls round-robin.
10-05-2012 02:50 AM
Both are matched, both will be used.
To use multiple port, use trunk-group configuration, not multiple DPs.
10-05-2012 02:55 AM
Hi Paolo,
the port is different.
Does it affect the matching process?
The config is for a VWIC3-2MFT-T1/E1.
If all 32 channels on port 0/0/0 are busy, will the calls go to the second one 0/0/1?
Thanks.
10-05-2012 02:59 AM
Calls go to both ports. Use trunk-group for easier configuration and more control.
10-05-2012 03:05 AM
Could you please explain this in detail? ...with both dial peers. i don't really understand how the calls go in/out if 2 ports are used.
10-05-2012 03:07 AM
10-05-2012 03:52 AM
thanks.
10-05-2012 08:22 AM
Thank you for the nice rating and good luck!
