dial-peer pots incoming redirect
Vincenzo Errante
Beginner
Beginner
there is a command that is equivalet to the connection PLAR of the voice port, for the dial-peer pots ??.
my problem is that i want to connect an ephone with a specific called isdn number.
the isdn bri haven't DID.
18 Replies 18
well see the attachment
(out call with this PVDM are all ok and are ok if I use bri associated with ivr)
I saw the attachment. The point is that you have enough PVDM resources for (possibly) 2 x BRI, but certainly not for 4.
As mentioned above, you should replace the incompatible PVDM-2 with a PVDM-256k-xx to have all the BRI ports working.
ok tnx
i will check this conf in a new router 2800 series :)
(grazie.. almeno questo in italiano :) )
A PVDM2-256K-xx will be enough. I have 1760 working beautifully with CME and 12.4(4)XC
Problem is that the VIC-2BRI you have is not compatible with the ISR router so you can't reuse them.
Grazie per l'apprezzamento e saluti alla bella Sardegna.
Recognize Your Peers
