01-28-2012 01:50 AM - edited 03-16-2019 09:16 AM
Dear Sir,
How can i divert one specific calling number ( ANI) to session target 2, when all other ANIs are going to session target 1 using voip dial peer?
Call is coming from pstn on pots and move to softswitch on voip dial-peer.
I have implemented following scenario...
My calling number is 512112152. Actually i rejected my ANI on rule 1000 and pass all other ANIs. then on rule 1001 i am passing my ANI. These two rules are shown below :
voice translation-rule 1000
rule 1 reject /^512112152/
rule 2 // // type any national plan any isdn
voice translation-rule 1001
rule 1 /512112152/ //
Then implemented these translation rules on translation profiles as :
voice translation-profile geo
translate calling 1001
voice translation-profile national
translate calling 1000
translate called 1550
Now pots dial peer is used to get the call from ANi from PSTN and dial peer is as :
dial-peer voice 102 pots
translation-profile incoming Remove-C
incoming called-number .T
direct-inward-dial
port 7/3:D
Now Voip dial-peers are used to out the call to two different session targets. Dial peer 1001 is used to route all other calls to session target 221.120.227.74 and dial-peer 9002 is used to route call from ANI 512112152 to session target 221.120.212.197. Both these dial-peers are as :
dial-peer voice 1001 voip
description Towards Advance VOIP
translation-profile outgoing national
preference 1
destination-pattern .T
voice-class codec 1002
session protocol sipv2
session target ipv4:221.120.227.74
dtmf-relay rtp-nte
fax-relay ecm disable
fax rate 14400
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
dial-peer voice 9002 voip
description GEO PRI Diversion
translation-profile outgoing geo
answer-address 512112152
voice-class codec 1001
session target ipv4:221.120.212.197
dtmf-relay rtp-nte
fax rate 9600
Now issue is that my call from ANI 512112152 is not reading dial-peer 9002 and is always reading 1001 as other call does.
Now please tell me which command is used to route calling number that is
1.answer address
2. destination pattern
And these commands used in which dial-peer that is pots or voip.
Please guide me more. Its not working.
01-28-2012 11:34 AM
Confusingly anough, either should be working, because destination-paattern also matches ANI on incoming DPs.
However remember that if you use answer-address, then there is no so subsequent match search as tie-breaker, it is kind of strange but that's the way it works.
01-29-2012 02:00 AM
Hi Paolo,
there is only one incoming dial-peer and that is of POTS which is used to get all calls from PSTN irrespective of ANIs.
My issue is that one of my customer name GEO having its PRI 512112xxx. i want to divert all calls from this PRI to session target .197 of voip dial-peer 9002 but its not happening and all calls from PRI reading voip dial-peer 1001 and moving to session target .74
Please guide more.
Bilal
01-28-2012 03:37 PM
Hi Bilal,
I've seen that you have a translation on your pots Dialpeer for incoming, what about that rule?
"translation-profile incoming Remove-C"
Maybe you translate here something, so that you won't match your "answer adress Dialpeer"?
Cheers
Torsten
01-29-2012 01:53 AM
Hi Torsten,
Thanks for your reply....
The translation profile which you are pointing out is only for removal of caharacter "C" as some of TDM exchanges send C with incoming number so we used that profile in pots dial-peer as :
voice translation-rule 1450
rule 1 /C/ //
voice translation-profile Remove-C
translate called 1450
Is this effect our answer address command used in dial-peer 9002 to divert ANI 512112152 to session target .197?
if not whats then, why 512112152 not reading 9002 voip dial-peer?
My only concern is that one of my customer name GEO having its PRI 512112xxx. i want to diver all calls from this PRI to session target .197 of voip dial-peer 9002 but its not happening and all calls from PRI reading voip dial-peer 1001 and moving to session target .74
Please guide more.
Bilal
