11-19-2018 12:18 AM
I am unable to make end to make calls on my gateway AS5300. I have configured channel-group which disables the voice port command and I have to use trunk group.
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_api_call_setup_ind: (vdbPtr=0x62B9CE80, callInfo={called=243020096,called_oct3=0x80,calling=12345,calling_oct3=0x0,calling_oct3a=0x80,calling_xlated=false,subscriber_type_str=Unknown,fdest=1,peer_tag=300, prog_ind=0,callingIE_present 1, src_route_label=, tgt_route_label= clid_transparent=0},callID=0x62F232D0)
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_api_call_setup_ind: type 0 , prot 3
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
1d02h: ccCheckClipClir: calling number is: "12345", calling oct3a is: 0x80
1d02h: Calling Party number is User Provided
1d02h: Leaving ccCheckClipClir
calling oct3 is: 0x0
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_api_call_setup_ind: (vdbPtr=0x62B9CE80, callInfo={called=243020096, calling=12345, fdest=1 peer_tag=300}, callID=0x62F232D0)
1d02h: //3/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: Increment call volume: 0
1d02h: //3/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: current call volume: 1
1d02h: //3/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: entry's incoming TRUE.
1d02h: //3/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_insert_call_entry: is_incoming is FALSE
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDConstructHashProfileTab: profileTable[0x62BFE0D0], numBuckets[11], numEntries[0]
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/ccTDPvtProfileTableBuildManager: Invoking necessary profileTable updaters...
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: Updating profileTable[0x62BFE0D0] with objects in container[0x62BFAD54]
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: obtained key[5] for the tag[6]
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x62BFE0D0], tdObject[0x62F9BEC4]
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDPvtUpdateProfileTabFromContainer: obtained key[1] for the tag[20]
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x62BFE0D0], tdObject[0x62BFE064]
1d02h: ccTDUtilDumpAllElemInProfileTab: profileTable[0x62BFE0D0], numBuckets[11], numEntries[2]
1d02h: Bucket { 1 } ------>0x62BFE064[0x0,t-20,l-28,d-0x62BFE084,m-3,u-95461,g-FACE0FFF]
1d02h:
1d02h: Bucket { 5 } ------>0x62F9BEC4[0x0,t-6,l-16,d-0x62F9BEE4,m-3,u-95461,g-FACE0FFF]
1d02h:
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDDestructTDUsrContainer: Container[0x62BFAD54]
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: remote IP is 192.168.1.9
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: hwidb is Ethernet0
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_incr_if_call_volume: create entry in list: 1
1d02h: Queued event from SIP SPI : SIPSPI_EV_SEND_MESSAGE
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/cc_process_call_setup_ind: (event=0x62DBDCC8)
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup: matching parameters - called# [243020096], calling# [12345], consultid []
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_setupind_match_search: Searching for node with called# [243020096], calling# [12345], consultid
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup: No matching node
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/cc_process_call_setup_ind: >>>>CCAPI handed cid 3 with tag 300 to app "DEFAULT"
1d02h: //3/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(24=CC_EV_CALL_SETUP_IND), cid(3), disp(0)
1d02h: //3/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(SSA_EV_CALL_SETUP_IND), cid(3), disp(0)
1d02h: //3/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/SSAPP:-1:-1/ssaCallSetupInd:
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/ccCallSetContext: (callID=0x3, context=0x63119C20)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaCallSetupInd: cid(3), st(SSA_CS_MAPPING),oldst(0), ev(24)ev->e.evCallSetupInd.nCallInfo.finalDestFlag = 1
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaCallSetupInd: src route label=, tgt route label= tg_label_flag 0x0
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaCallSetupInd: finalDest cllng(12345), clled(243020096) tgt_route_label()tg_label_flag 0x0
1d02h: Inside dpMatchPeersMoreArg
1d02h: dpMatchPeersMoreArg: Match Dest. pattern; called (243020096)
1d02h: Inside dpMatchCore:
1d02h: destination pattn: 243020096 expanded string: 243020096
1d02h: MatchNextPeer: Peer 300 matched
1d02h: MatchNextPeer: Peer 200 matched
1d02h: dpMatchPeersMoreArg: Result=0 after MATCH_ORIGINATE
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaCallSetupInd: cid(3), st(SSA_CS_CALL_SETTING),oldst(0), ev(24)dpMatchPeersMoreArg result=
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaDebugPeers: ssaSetupPeer cid(3) peer list: tag(300) called number (243020096) tag(200) called number (243020096)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaSetupPeer: dialpeer tags in rotary= 300 200
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaSetupPeer: cid(3), destPat(243020096), matched(0), prefix(), peer(62DF5CF0), peer->encapType (2)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaSetupPeer: cid(3), can't gateway with peer tag(300))
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaSetupPeer: cid(3), destPat(243020096), matched(0), prefix(), peer(62F9D8A8), peer->encapType (1)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/ccCallProceeding: (callID=0x3, prog_ind=0x0)
1d02h: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/ccCallSetupRequest: (Inbound call = 0x3, outbound peer =200, dest=,
params=0x62DD1460 mode=0, *callID=0x62DD1A30, prog_ind = 0callingIE_present 1)
1d02h: ccCallSetupRequest numbering_type 0x80
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/ccCallSetupRequest: (outbound peer =200, trunkgrouplist = 0x62F9E870)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/ccCallSetupRequest: tgrm_select_interface failed
1d02h: ccCallSetupRequest: decremented counter 0
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaSetupPeer: try next peer cid(3), rc(-14)
1d02h: //3/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: CallID[3], tagID[24], instID[-1]
1d02h: //3/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDUtilGetDataByValue: No tdObject found in profileTable for tagID[24] of callID[3]
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDUtilSetDataInstance: Setting data for callID[3], tagID[24], instID[-1], data[0x62DD0FCC], dataSize[4]
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDConstructInstanceTDObject: tdObject[0x62BFACBC], nxtElem[0x0], magic[0xFACE0FFF] tagID[24], dataLen[4], modif[4]
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDPvtAddObjectToProfileBucket: profileTable[0x62BFE0D0], tdObject[0x62BFACBC]
1d02h: ccTDUtilDumpAllElemInProfileTab: profileTable[0x62BFE0D0], numBuckets[11], numEntries[3]
1d02h: Bucket { 0 } ------>0x62BFACBC[0x0,t-24,l-4,d-0x62BFACDC,m-4,u-95461,g-FACE0FFF]
1d02h:
1d02h:
1d02h: Bucket { 5 } ------>0x62F9BEC4[0x0,t-6,l-16,d-0x62F9BEE4,m-8,u-95461,g-FACE0FFF]
1d02h:
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaDebugPeers: ssaFlushPeerTagQueue cid(3) peer list: (empty)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/ccCallDisconnect: (callID=0x3, cause=0x2C tag=0x0)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/ccCallDisconnect: calling accounting start for callID=3 leg_type=1
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/ccCallDisconnect: existing_cause = 0x0, new_cause = 0x2C
1d02h: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/ccCallReportDigits: (callID=0x3, enable=0x0)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/cc_api_call_report_digits_done: (vdbPtr=0x62B9CE80, callID=0x3, disp=0)
1d02h: //3/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(56=CC_EV_CALL_REPORT_DIGITS_DONE), cid(3), disp(0)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaTraceSct: cid(3)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_REPORT_DIGITS_DONE)
oldst(SSA_CS_MAPPING)cfid(-1)csize(0)in(1)fDest(1)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaDebugPeers: ssaReportDigitsDone cid(3) peer list: (empty)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaReportDigitsDone: callid=3 Reporting disabled.
1d02h: Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.1.9:5060;branch=z9hG4bK3b619422
From: "12345" <sip:12345@192.168.1.9>;tag=as7445d680
To: <sip:243020096@192.168.1.3:5060>;tag=5B09EBC-1B33
Date: Sun, 18 Nov 2018 21:15:34 GMT
Call-ID: 7b70b2b85243dc944f99a29a349eb7ed@192.168.1.9:5060
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 102 INVITE
Allow-Events: telephone-event
Content-Length: 0
1d02h: Sent:
SIP/2.0 500 Internal Server Error
CSeq: 102 INVITE
Content-Length: 0
1d02h: Received:
ACK sip:243020096@192.168.1.3:5060 SIP/2.0
Max-Forwards: 70
Contact: <sip:12345@192.168.1.9:5060>
CSeq: 102 ACK
User-Agent: Asterisk PBX SVN-branch-1.8-r330213M
Content-Length: 0
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_api_icpif: expect factor = 10
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/ccCallGetVoipFlag: ccCallGetVoipFlag: callID=0x3, mask=1
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: the remote IP is 192.168.1.9
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: hwidb is Ethernet0
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: reduce callnum of entry: 0, voip: 0, mmoip: 0
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/cc_decr_if_call_volume: remove an entry
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/cc_api_call_disconnect_done: (vdbPtr=0x62B9CE80, callID=0x3, disp=0, tag=0x0)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/cc_delete_call_entry: Decrement call volume counter 1
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/cc_delete_call_entry: current call volume: 0
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/cc_delete_call_entry: entry's incoming TRUE.
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/cc_delete_call_entry: is_incoming is FALSE
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/CCAPI/cc_delete_call_entry: Deleting profileTable[0x62BFE0D0]
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDDestructTDHashProfileTab: Destructor Profile Table (0x62BFE0D0)
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDDestructInstanceTDObject: tdObject[0x62BFACBC] tagID[24]
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDDestructInstanceTDObject: tdObject[0x62BFE064] tagID[20]
1d02h: //-1/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/CCAPI/ccTDDestructInstanceTDObject: tdObject[0x62F9BEC4] tagID[6]
1d02h: //3/xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx/SSAPP:-1:-1/sess_appl: ev(12=CC_EV_CALL_DISCONNECT_DONE), cid(3), disp(0)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaTraceSct: cid(3)st(SSA_CS_DISCONNECTING)ev(SSA_EV_CALL_DISCONNECT_DONE)
oldst(SSA_CS_DISCONNECTING)cfid(-1)csize(0)in(1)fDest(1)
1d02h: //3/EBE2054F-EAAD-11E8-8004-887AD6F6F0C9/SSAPP:300:-1/ssaDisconnectDone:
1d02h: dp_check_for_tg_ch tg_label CAMTEL up 0
1d02h: dp_check_for_tg_ch peer_tag 200
Nov 18 21:35:33: %SYS-5-CONFIG_I: Configured from console by vty0 (192.168.1.1)
1d02h: dp_delete_route_label_member_by_index
1d02h: dp_delete_route_label_member_by_index:Existing dialpeer route label is null
1d02h: dp_add_route_label_member_by_index
1d02h: dp_create_carrier
1d02h: dp_create_carrier Added Serial0:16 to route label list
1d02h: dpCheckTerminationStatus : No TG with channel
Nov 18 21:52:24: %SYS-5-CONFIG_I: Configured from console by vty0 (192.168.1.1)
trunk group CAAV
carrier-id camtel
voice-class cause-code 1
hunt-scheme round-robin
isdn supp-service tbct
translation-profile outgoing 200025023..
isdn switch-type primary-net5
isdn voice-call-failure 0
voice service pots
voice service voip
signaling forward unconditional
h323
sip
session transport tcp
voice class codec 1
codec preference 1 g729r8
codec preference 2 g723r53
voice source-group CAAV
translation-profile incoming ipv4:192.168.1.9:5060
trunk-group-label source Ethernet0
trunk-group-label target Serial0:16
voice translation-rule 1
fax interface-type fax-mail
dial-control-mib retain-timer 240
dial-control-mib max-size 100
controller E1 0
clock source line primary
channel-group 16 timeslots 1-15,17-31
controller E1 1
clock source line secondary 1
dial-peer voice 300 voip
answer-address 20025023T
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target ipv4:192.168.1.9:5060
dtmf-relay rtp-nte
dial-peer voice 200 pots
trunkgroup Serial0:16 1
incoming called-number .
direct-inward-dial
no dial-peer outbound status-check pots
sip-ua
retry invite 3
retry bye 3
retry cancel 3
timers trying 1000
sip-server ipv4:192.168.1.3:5060
11-19-2018 09:05 AM
The call cannot find a matching dial-peer
I'll suggest to revisit your dial-plan configuration, you should not combine incoming called-number, answer-address or destination-pattern
Please refer to the following URL to understand the matching process: https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html?referring_site=smartnavRD#topic3
