Dial-peer
Aleksei.Zjabkin
Hi everyone!
Does dial-peer requires a DSP channel?
Best Regards,
Aleksei
ronpatel
Level 8
Level 8
No Dial-peer configuration will not use DSP channels.
Ronak Patel
Please rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
ronpatel
Level 8
Level 8
Ronak Patel
Just to add to Ronak's response:
The POTS-facing ports (PRI, BRI, FXO/FXS, E&M, etc) require DSPs to convert the analog or digital TDM audio into RTP packets. So, the dial-peer itself doesn't but any POTS interfaces it references does. This is not the case with VoIP dial-peers unless you need to do transcoding between codecs.
