01-18-2011 12:32 PM - edited 03-16-2019 02:56 AM
I'm hoping someone can help me wrap my head around this. Nothing is broken, I'm just trying to get a better understanding of how dial peers and voice ports work. I've been reading the white papers provided by cisco, and I end just end up more confused.
Below is my working config of a voice T1 between two routers. I've cleaned it up a little bit to get rid of any lines that don't pertain to my confusion ( fax pass through commands, g711 commands, etc).
The attached JPG shows exactly what I'm trying to do. In the JPG, I'm trying to figure out what has to match up with what in order for this to work. I'm just dealing with the signaling channel. Once I understand the signaling, the voice bearers will follow the same logic. As you can see, the number 11300 shows up three different times on one side and three times on the other. Are any of these just arbitrary labels that someone happened to name 11300 for consistency's sake? Again, I think the JPG will explain exactly what I'm trying to figure out. Thanks in advance.
*****HEAD END **********
controller T1 0/1/1
ds0-group 0 timeslots 24 type ext-sig
ds0-group 1 timeslots 1 type ext-sig
.... continue on from 1 all the way to 23...
ds0-group 23 timeslots 23 type ext-sig
voice-port 0/1/1:0
connection trunk 11300
voice-port 0/1/1:1 - 23
connection trunk 11501 - 23
dial-peer voice 11300 voip
description Signalling Channel
destination-pattern 11300
session target ipv4:X.X.X.X
dial-peer voice 11500 voip
description Voice Bearer Channels
destination-pattern 115..
dial-peer voice 11400 pots
destination-pattern 11400
port 0/1/1:0
dial-peer voice 11601 - 23 pots
destination-pattern 11601 - 23
port 0/1/1:1 - 23
____________________________________
********** REMOTE END ****************
controller T1 0/0/0
.... continue on from 1 all the way to 23... ....
voice-port 0/0/0:0
connection trunk 11400
voice-port 0/0/0:1 - 23
connection trunk 11601 - 23
dial-peer voice 11400 voip
dial-peer voice 11600 voip
destination-pattern 116..
dial-peer voice 11300 pots
port 0/0/0:0
dial-peer voice 11501 - 23 pots
destination-pattern 11501 - 23
port 0/0/0:1 - 23
01-19-2011 02:40 AM
When you configure T-CCS cross-connect for E1 or T1, you set up time slot groups, and then configure cross-connect from the first T1/E1 controller to the second T1/E1 controller. The mode ccs cross-connect command allows the cross-connect. This command enables all the channels to perform similarly to normal CAS mode, except that the signaling bit is no longer processed by the router.
Here's a doc which will solve your doubts... If that doesn't help let me know
PS: Rate useful posts
01-19-2011 02:47 AM
After a bit of google.. here's a Cisco press book
Page 210 @
01-19-2011 09:36 AM
Thank you for this! I'll be taking a deeper look later this afternoon.
01-19-2011 09:41 AM
No Problemo
Ping me here if you don't understand anything.. It should be pretty
straight forward.
Cheers,
Divin
03-24-2011 12:49 PM
got it to work without mode ccs.
What is the default mode without your statement?
thanks,
