06-27-2013 08:44 AM - edited 03-16-2019 06:06 PM
Seeing these Dial Peers bounce:
%SIP-5-DIALPEER_STATUS: VoIP dial-Peer <22> is Busied out
%SIP-5-DIALPEER_STATUS: VoIP dial-Peer <22> is Up %SIP-5-DIALPEER_STATUS: VoIP dial-Peer <22> is Busied out
Any documentation on these errors, possible root causes, how do I know which Dial Peer is bouncing?
thanks,
06-27-2013 08:53 AM
Do you have sip options ping configured on the CUBE?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
06-27-2013 09:58 AM
Yes we do:
voice-class sip options-ping 60
voice-class sip options-keepalive
06-27-2013 12:42 PM
What is most likely going on is that the far end to which the dial-peer points to is not responding to options ping, hence CUBE is busying out the dial-peer...This suggests that that sip trunk may be down...
Send us a debug ccsip messages and we will see whst happening to the options ping
04-05-2016 07:17 AM
I have the same issue.
*Apr 5 06:07:14.093: %SIP-5-DIALPEER_STATUS: VoIP dial-Peer <7> is Busied out
To what is the <7> referring, I don't have a dial peer 7 in my configuration ?
04-05-2016 07:49 AM
Hi Luk,
If you do not have dial-peer 7 configured, then you are hitting the defect : CSCug87860
~Amit
Please rate if helpful
04-05-2016 08:04 AM
Hi Amit,
Could this explain that some call's are not delivered ? I have done some test and most of the times the call is not delivered. And then suddenly it's delivered.
Our Phone company says that we send a BYE within msec to them during the failed calls.
Thank you.
04-05-2016 08:21 AM
Hi Luk,
It appears to display the dial-peer interface index instead of the dial-peer tag.
To find out which dial peer the index number belongs enable SNMP trap on router using below command:
snmp-server trap link ietf
We can see the index number mentioned in error is mapped to which dial peer using below debug.
debug snmp packets
Regarding your call issue, if the dial-peer is in down status, we do not send BYE, we send 5XX SIP message in response.
A BYE is only sent when the call is connected already and then disconnect due to any reason. BYE is never sent if the SIP transaction is not completed.
~Amit
06-13-2016 09:19 AM
You can view the mappings between the SNMP ifindexes and the VOIP dial-peers by using the command;
sh snmp mib ifmib ifindex | i Voice Over IP Peer
06-20-2018 08:48 PM
Hi Luk,
Have you seen a fix for this bug: CSCug87860? Which version fixes this issue I am not able to find it on Cisco site. Let me know please.
10-07-2015 09:44 AM
I was able to resolve this issue by modifying the "retry" parameter in our SIP OPTIONS profile from 1 to 2.
voice class sip-options-keepalive 1
down-interval 10
up-interval 5
retry 2
04-05-2016 07:52 AM
Generally we get such errors if we have configured our cube for OPTION ping, and if there is a network connectivity failure between cube and cucm, then cube marks the dial-peer as down after certain re-tries with option ping.
If you are getting the above messages and the dial-peer is not even configured on your cube, then we are hitting the defect:CSCug87860.
~Amit
06-20-2018 08:52 PM
