dial peers help
dimigav1977
I have registered an single number on service provider.
I have the following configuration on an C2901 router with 4 fsx ports and uck9 license installed. On the fxs0/1/0 and fxs0/1/1 ports of the router are plugged analog phone devices.
I also have a second telephone registered on another provider that is not found in the attached config file.
Lastly I have a cisco IP Phone CP-8961.
So, all the phone devices (analog and IP) I want to make calls from the first registered number that you see on config file.
The analog devices take calls only from first registered number and the IP phone take calls from the second registered number.
So, the questions are.
How can I add the second provider with the following details.
SIP Account Details:
Title: modulus
Username: <username>
Password: <password>
Domain: voips.modulus.gr
Advanced Settings:
NAT Traversal: Off
STUN Server: empty/disabled
TURN settings: empty/disabled
Outbound proxy: disabled
Codecs:
Select: g.722, g.711 a-Law, GSM | All others disabled
DTMF mode:
Select only "RFC 2833"
and how can I set the dial peers.
Possibly you might have forgot to add the intended file with the referenced configuration. Apart from that it’s not all clear what you’re provided information has to do with the topic of your question, ie help with dial peers. Would you mind to please elaborate on what you require help with?
Response Signature
