4254
Dial peers in MGCP
     I have a cisco 3825 gateway and would like to add a second PRI. I have configured the Call Manager gateway to take the second PRI on 0/2/1. When I looked at the configuration on the 3825 gateway I got confused when I saw Dial-peer with port 0/2/0:23. I thought that if I set it in the call manager the MGCP gateway would get the configuration from the call manager and no dial-peer would be needed in the gateways configuration. How can I add the second PRI on the gateway and have call manager use it? What is the use for dial-peers?
dial-peer voice 9 pots
service mgcapp
port 0/2/0:23
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
port 0/2/0:23
dial-peer voice 911 pots
destination-pattern 911
no digit-strip
port 0/2/0:23
dial-peer voice 9911 pots
translation-profile outgoing OUTBOUND_STRIP9
destination-pattern 9911
no digit-strip
port 0/2/0:23
dial-peer voice 100 pots
destination-pattern 9[2-9]......
no digit-strip
port 0/2/0:23
dial-peer voice 101 pots
destination-pattern 9[2-9]..[2-9]......
no digit-strip
port 0/2/1:23
dial-peer voice 102 pots
destination-pattern 91[2-9]..[2-9]......
no digit-strip
port 0/2/1:23
dial-peer voice 103 pots
destination-pattern 9011T
no digit-strip
port 0/2/1:23
3 REPLIES 3
Clifford McGlamry
Rising star
Those dial peers are for SRST use most likely (if the gateway is in MGCP mode).
The circuit is added to MGCP control by defining the PRI under the controller with something like:
pri-group timeslots 1-24 service mgcp
And under the serial interface you may need to add:
isdn bind-l3 ccm-manager
You do not normally need the dial peer to place a T1 under MGCP control because it's defined under the controller.  As a result, the following from your config probably isn't needed:
service mgcapp
port 0/2/0:23
You would need something like the above for an analog port (FXO or FXS).
Cliff
Clifford,
     I copied and pasted the voice configuration of the 3825 gateway. We don’t use SRST since we have one site. We have two call managers and two gateways (3825&2811). I am adding a second PRI to the 3825 gateway; I have configured the second VIC endpoint in call manager under gateway configuration. Both gateways are running MGCP and are controlled by call manager. Is there any reason why I should have the dial peers other than for SRST? Can you see any mistakes on my voice config?
isdn switch-type primary-dms100
voice-card 0
no dspfarm
voice call carrier capacity active
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
voice translation-rule 1
rule 1 /^9/ //
voice translation-profile OUTBOUND_STRIP9
translate called 1
controller T1 0/2/0
framing esf
linecode b8zs
cablelength long 0db
description AT&T VOIP PRI - ***-***-0041
controller T1 0/2/1
framing esf
linecode b8zs
description AT&T VOIP PRI - ***-***-8789
ip ssh time-out 60
ip ssh version 2
interface Tunnel1
no ip address
interface GigabitEthernet0/0
ip address 10.10.0.14 255.255.255.0
duplex full
speed 1000
media-type rj45
no mop enabled
interface GigabitEthernet0/1
no ip address
shutdown
duplex full
speed 1000
media-type rj45
interface Serial0/2/0:23
description AT&T VOIP PRI Channels - ***-***-0041
no ip address
encapsulation ppp
isdn switch-type primary-ni
isdn incoming-voice voice
interface Serial0/2/1:23
description AT&T VOIP PRI Channels - ***-***-8789
no ip address
encapsulation ppp
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/2/0:23
echo-cancel coverage 24
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/1:23
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.10.0.8
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.10.0.9
ccm-manager config
mgcp
mgcp call-agent 10.10.0.9 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package fxr-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 gateway force
mgcp rtp payload-type g726r16 static
mgcp behavior g729-variants static-pt
mgcp profile default
service mgcapp
port 0/2/0:23
direct-inward-dial
port 0/2/0:23
no digit-strip
port 0/2/0:23
no digit-strip
port 0/2/0:23
no digit-strip
port 0/2/0:23
no digit-strip
port 0/2/0:23
no digit-strip
port 0/2/0:23
no digit-strip
port 0/2/0:23
dial-peer voice 10 pots
service mgcapp
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 10.10.0.14 port 2000
max-ephones 100
metalium2007
Participant
Please take a careful look at the following doc:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf1.html
Rgds
met
Create
Recognize Your Peers
Content for Community-Ad
