06-30-2016 07:38 PM - edited 03-17-2019 07:25 AM
We use 0 dial out and ever since we have migrated to sip trunk we get full e.164 DID on all inbound calls. Which means we receive +1<10 digits>
Problem we are having is on call back so if we have a missed call, we need to do edit dial and get rid of + and populate 0 to complete the call,is there a way around this so we can directly dial the number from missed calls?
06-30-2016 07:55 PM
You always need to mention what you're working with, and not just what you want to achieve.
CUCM?? CME?? version??
First thought, would be to just configure a translation rule to do that, as you get all inbound calls in the same format.
06-30-2016 08:00 PM
This is a CUCM version 11.0.1
06-30-2016 08:55 PM
OR, you can configure translation pattern to do that in cucm, so outgoing call hit first at translation pattern and then after manipulation, it should go to route patter.
Suresh
