07-13-2012 02:40 AM - edited 03-16-2019 12:10 PM
I have a problem implementing my dial plan on CUCM 8.6.
I have a translation pattern 049.1XXX (Predot) for internal calls . When i try to call an external number 0491509352 i receive a message from CUCM saying thet the call cannot be completed and the call is not routed to the gateway. I know it's normal because there is no extension 1509 on CUCM.
How can i resolve this problem without adding any digit?
Thank you in advance
Solved! Go to Solution.
07-13-2012 03:34 AM
HI
Please de select Translation Pattern Configuration. This will resolve your issue.
Ronak Patel
Rate helpful posts.
07-13-2012 02:49 AM
Do you have route pattern for this number 0491509352?
Ronak Patel
07-13-2012 03:00 AM
Yes of course 04XXXXXXXX and the CSS can reach this pattern
07-13-2012 03:20 AM
Hi Youssef,
Still a little unclear as to what are your requirements, can you trace the call flow something like this
ip phone-->> TP-->> CUCM-->> Gw etc... and let us know what you are looking to achieve.
Niket
07-13-2012 03:28 AM
i have an internal extensions 1000 , 1001 ... 1010 in Germany Partition.
Ip phones on other partitions (usa, france etc...) shoul call 04910XX to reach this phones. that's why i created a translation pattern 049.1XXX to reach them from other regions.
At the same time , i want to call a PSTN number : 0491509352 that cannot be routed because it matches the translation pattern and not the route pattern 04XXXXXXXX .
I don't want to add an additional digit .
07-13-2012 03:34 AM
HI
Ronak Patel
Rate helpful posts.
07-14-2012 02:50 PM
Thanks Ronak,
That did the trick!!
regards
