04-13-2017 02:21 AM - edited 03-18-2019 12:13 PM
Our system is quite old, and was setup with the line-blocking method for access control. (i.e. Device CSS lists all the gateways, and the line CSS blocks certain patterns) We've become aware that this design has its limits and is no longer being promoted by Cisco.
I've had a look at the SRND for CUCM 11.5 ( http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab11/collab11/dialplan.html ) to find out what the current recommendation is for dial plan access control. But I think I'm being an idiot, as I can't see in that document how you implement dial access control.
What is the current recommendation for implementing access control?
04-13-2017 06:32 AM
Interesting question, we are still with the same method as well.
From where you found out that this design has its limits and which ones pls ?
I've went quickly thru the SRND without finding the recommendation on this neither.
04-13-2017 06:54 AM
I was told there were two main reasons for abandoning the line-blocking design:
04-13-2017 07:17 AM
About e164 numbering, the main issue is globalization where we usually send all calls to a Partition TP_to_e164.
Check the very handy option in the TP level "Use Originator's Calling Search Space". You can do something like this
css_l
p_no_gsm
css_d
p_to_e164
p_e164
p_internal
TPs in
p_to_e164 with css_to_e164
Option "Use Originator's Calling Search Space" checked
TPs in
p_no_gsm
\+(GSM format here)
blocked
RP for PSTN access in
p_e164
\+.! pointing to LRG
Short internal extensions and e164 alias are put in p_internal
How's that ?
04-13-2017 07:19 AM
Yes, I've recently discovered the "Use Originator's Calling Search Space" option on a translation pattern. It does make things easier!
04-13-2017 07:28 AM
Still would like to have an official design recommendation from Cisco.
Or any other design is welcome.
Please rate helpful post.
HTH.
04-13-2017 07:19 AM
About SIP URIs, you can always set up SIP Patterns to block and put them in the Line CSS right ?
04-13-2017 06:56 AM
Thinking about this a bit more, the question is more: What do you do where in Line Vs Device CSSs?
Onnet dial plan patterns in device CSS and PSTN patterns (& hence restrictions by not listing undesirables) in the line CSS?
