06-22-2011 10:36 AM - edited 03-16-2019 05:35 AM
I have a CUCM 8.5.1 cluster. DNA service is running and activated on all 3 CUCM's.
Getting the following warning message when running analyzer:
"DNA is still initializing. Please refresh page and try again after sometime"
Refreshing the page only clears the text boxes on the page and never returns any results.
Has anyone seen this before?
06-22-2011 10:46 AM
06-22-2011 10:49 AM
It sure does - Thanks Rob
12-12-2011 05:41 AM
I have faced same problem. (after upgrade from 8.0 to 8.5 version)
I will do what huffman said and inform you .
01-11-2012 10:25 AM
Hi All.
Workaround solved my problem. Thanks.
10-25-2012 11:07 AM
Workaround crashed my publisher. All services stopped unexpectantly, some services won't restart via web or cli.
10-25-2012 11:38 AM
Hi there,
It's possible you've hit this bug now
CSCtw97158 - If activating DNA without 'DNA Server' service, various services stop
Description
Status:
Open
Last Modified:
Sep 11,2012
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
6 - enhancement
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
10-25-2012 12:02 PM
Thanks Rob.
05-30-2013 11:58 AM
Thanks Rob!
Stopped DNA Service, Activated DNA Server, Restarted DNA Service
Resolved my DNA Still initializing issue on 8.5.1
Thx,
JDonahue
Symptom:
After L2 upgrade from 8.0 to 8.5 when DNA is launched, and the user tries to analyze a pattern the pop-up indefinitely shows that it is still initializing.
Conditions:
if DNA was activated in 8.0 and it is upgraded to 8.5, the DNA service is not activated, since the new service "DNA Server" service added in 8.5 is not activated during upgrade
Workaround:
1. Deactivate both the DNA services.
2. Activate "Cisco Dialed Number Analyzer Server" service first
3. Then Activate "Cisco Dialed Number Analyzer" service
Symptom:
Conditions:
Workaround:
10-04-2012 09:02 AM
This did not work for me. I have 3 servers and I deactivated both services in all 3 servers. I then went and activated the DNA server on each ands then went back and activated the Service on each server and I still get the same message.
10-04-2012 09:22 AM
Abouth 30 mins later I tried again and it works! Have some patience when trying this workaround!
10-31-2012 12:35 PM
This workaround worked for us as well. It took about 5 minutes but DNA is now working.
02-27-2013 03:03 AM
The client has UCM 8.6.4 and the DNA stopped all of a sudden. We restarted the DNA services and that did it.
Tiberie
11-20-2013 08:52 AM
I am running cucm 8.5.1 and used the troubleshooting tips. It worked for me.
