03-06-2012 01:01 PM - edited 03-16-2019 09:58 AM
Hello all,
there is a question which must be very trivial but I'm stuck searching for answer.
There is a CCME system connected to PSTN through FXO ports and a few IP phones registered on the CCME system (SCCP protocol is in use). Destination pattern for outgoing calls is 9T, if my info is correct.
So, after users dial 9 and a proper number (911111, for instance) and the connection is established, they can see only 9 on their screens rather than 911111. Quite weird.
Unfortunately I don't have a complete config at my hand, so I'd be very grateful for any ideas before I tackle the issue.
Tieken
03-06-2012 08:45 PM
Tieken,
What CCME version it is ?
Also, it's extreemly important to see the configuration to give precise ideas as to what must be causing this.
GP.
03-06-2012 08:57 PM
The CCME version is 8.6.
I shall attempt to get the config.
