04-04-2018 02:08 AM - edited 03-17-2019 12:33 PM
Can we make Hunt Pilot a DID? Because i am trying to make hunt pilot DID so that outside callers can call directly Hunt pilot number and then to Hunt list and to Line Group. In nutshell , It will act as a ccx.
Is this possible?
04-04-2018 04:00 AM
Yes, yes and yes, it is possible.
treat it the same as an extension on your phone. so if you have say a 100 number range DID and you use like 4XXX as your internal extensions. the for instance 4001 can be a hunt pilot, 4003 a phone etc etc.
04-04-2018 04:15 AM
04-04-2018 04:17 AM
dont hesitate to add to this post if you cant get it to work, and provide example of your number plan,. this shouldnt be to hard to achieve. cheers
04-04-2018 04:19 AM
