Diff in SIP and SCCP
Puneet Kohli
Can anyone please tell what is difference in using SIP or SCCP as Device protocol with CUCM.
Like If phone uses SCCP as device protocol in CUCM and if phone uses SIP as device protocol in CUCM is there any difference in features.
7 Replies 7
Aman Soi
Hi Puneet,
a. SIP is an open standard while SCCP is  cisco propreitory protocol.
b. Both use UDP as the transport medium for their media path.
c.Earlier there were few cisco phones which were supporting SIP but now Cisco is manufacturing SIP phones as well.
d. You can also integrate 3rd party phones to Cisco Call Manager as Basic and Advanced phone.
regds,
aman
Rakesh K
Hi Puneet,
You can use SCCP for your handsets and then use SIP trunking into a provider for your external calls. The CME Router will handle the signalling translation between SCCP and SIP for you.
Like everyone else here, I would always use SCCP for the handsets. Whilst Cisco are improving SIP handset features all the time between releases you still can't do everything you that you can do with SCCP. You would also need version 15 to support some of the more useful SIP handset stuff including Extension Mobility, and my own personal view of the code quality on the version 15 trains would use such language that it can't be mentioned here.
SCCP to the handset and trunking over SIP is perfectly valid and I've used it many times with great success.
regards
rakesh
Rob Huffman
Hi Puneet,
I thought I would add these docs in addition to the great info from
Aman & Rakesh (+5 guys )
They highlight the feature differences between in SCCP & SIP
in phone models;
Feature Support by Protocol for the Cisco Unified IP Phone 7975G, 7971G-GE, 7970G, 7965G, and 7945G
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7975G_7971g-ge_7970g_7965g_7945g/8_6/english/admin_guide/7970dif.html
Feature Support by Protocol for Cisco Unified IP Phones 7962G, 7942G, 7961G, 7961G-GE, 7941G, and 7941G-GE
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7962g_7961g_7961g-ge_7942g_7941g_7941g-ge/8_6/english/admin_guide/62614241apxb.html
Feature Support by Protocol for Cisco Unified IP Phone 7960G and 7940G
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7960g_7940g/7_0/sip/english/administration/guide/7960difS.html
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
Puneet Kohli
Thank you every one for your prompt reply but One thing i want to know ...If i two configure cisco 8945 model one using SIP and other using SCCP ....will both the phones have same features.......
Hi Puneet ,
I do not think there would be any challenge  in doing so unless you are looking for any specific feature.
regds,
aman
Rob Huffman
Hi Puneet,
Here we go
Feature Support by Protocol for the Cisco Unified IP Phone 8941 and 8945
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/8941_8945/8_5/english/admin_guide/6921apxg.html
Cheers!
Rob
"Talk about a dream
- Springsteen
Hi Mr. Rob,
Gr8  Sir....
regds,
aman
