Difference between Route pattern and Translation pattern?
Aswin S
Hi, Can someone clarify me the basic difference between Route Pattern and Translation Pattern? Is there any relation like incoming call to cucm handled by TP and Outgoing calls from cucm deal by RP? Please correct me if am wrong.
Simply i would like to know where and when to use TP and RP.
2 Accepted Solutions
Basic use of a translation pattern is to modify called or calling number information and then send it to either the same CSS as original or to a set CSS selected in the translation pattern. A route pattern basic use is to send the call to a route list or trunk/gateway directly. This can be a voice gateway to send the call to PSTN or a trunk to send to another internal system, like another CUCM. This is quite clearly described in documentation for CUCM.
Response Signature
Response Signature
Jaime Valencia
Might want to do some reading
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/8x/uc8x/dialplan.html
java
if this helps, please rate
