difference between unregistered unknown and rejected in ip phone status
hussen2015
Hello Everyone;
Can you please tell me the Difference Between unregistered unknown and rejected in ip phone status
Rajan
Unknown means actually the phone is either not connected or not in the network to reach the CUCM
Unregistered - If the phone registers once and rebooting for any reason or disconnected recently it will be in this state
Rejected - There is some issue with phone registration - you need to check the logs to find the reason code to identify the exact cause and troubleshoot
Rajan
Pls rate all useful posts
Rajan
Rajan
