ā12-23-2011 04:03 AM - edited ā03-16-2019 08:40 AM
Is it possible to put a PRI from one gateway and a PRI from a second gateway in the same route group?
To perform a sort of load balancing?
Bye,
JH
ā12-23-2011 04:11 AM
Yes in Route Group Configuration adds the IP Address of the gateways, and select the distribution algorithm that you want:
Top DownāIf you choose this distribution algorithm, Cisco CallManager distributes a call to idle or available members starting from the first idle or available member of a route group to the last idle or available member.
CircularāIf you choose this distribution algorithm, Cisco CallManager distributes a call to idle or available members starting from the (n+1)th member of a route group, where the nth member is the member to which Cisco CallManager most recently extended a call. If the nth member is the last member of a route group, Cisco CallManager distributes a call starting from the top of the route group.
See the Admin Guide of the CUCM, and in your case you can select the Circular Algorithm,
Rate this if is useful to you
Leonardo
ā12-23-2011 04:15 AM
Thanks.
In my case I have a 3845 with two PRI lines and a 2911 with 1 PRI lines.
All the lines are under MGCP configuration.
When I create a new Route Group I see all PRI lines, when I add the PRI line from the 2911 to the route group the PRI lines from the 3845 disapear and vice versa.
This is normal?
thanks,
JH
ā12-23-2011 04:19 AM
What is the procedure that you are doing?
you have Route Group A, you search the device after you find the device you click on "Add to Route Group" and save the config.
Do the same procedure on Route Group B.
ā02-17-2012 08:56 AM
A liitle late, but if the problem has been solved you should tell it..
After a reboot of the cluster everything was correct, I could assign the PRI lines in one group.
So the cluster just had a bad day.
JH
