Different tone for Internal / External calls on 7960 on SIP?
BensTechTips
I am using SIP and wish to configure my 7960G's to ring chirp1.pcm on an incoming internal call and to ring chrip2.pcm on an external call.
Is that possible by using some xml file on the SIP server?
dojoy
From what i know..
You will be able to change the cadence of the ring by setting "Offnet" on Gateway..
But not entirly differnt tone...
