12-15-2014 07:29 AM - edited 03-17-2019 01:19 AM
I have a CME system in Italy with a PRI connected. The problem I have is that when dialling out from any of the extensions the last 2 digits of the DDI number are missing. So for example if I dial from +39 02 251655899 the receiving phone only sees +39 02 2516558 on their display. I think this can be rectified by digit translation but I really don't know enough on the subject to work out how. Any help would be appreciated. Thanks
Solved! Go to Solution.
12-15-2014 08:48 AM
Sorry.
Wrong config :(
voice translation-rule 100
rule 1 /^58\(..\)/ /022516558\1/
Modify with the above config and try again.
Please send the output
Carlo
12-15-2014 09:00 AM
Hi.
Glad to help
Please rate all useful posts and mark as correct the answer that solved your issue to help others to identify useful posts.
Carlo
12-15-2014 07:41 AM
Hi.
Can you please post your config so I can give look to it and see if I can suggest you some improvements?
thanks
Carlo
12-15-2014 07:45 AM
Current config
cdmilanucrtr#show run
Building configuration...
Current configuration : 36655 bytes
! Last configuration change at 12:43:01 UTC Mon Dec 15 2014 by hv470
! NVRAM config last updated at 15:20:00 UTC Mon Dec 15 2014
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
service sequence-numbers
hostname cdmilanucrtr
boot-start-marker
boot system flash:c3900-universalk9-mz.SPA.152-4.M6a.bin
boot-end-marker
card type e1 0 0
card type e1 0 1
logging buffered 51200 warnings
enable secret 5 $1$O29Z$MI3fw5xIjDgY/FnpsBp5r.
aaa new-model
aaa authentication login default group radius line
aaa session-id common
clock timezone UTC 1 0
network-clock-participate wic 0
no network-clock-participate wic 1
network-clock-select 1 E1 0/0/0
crypto pki trustpoint TP-self-signed-2988842901
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2988842901
revocation-check none
rsakeypair TP-self-signed-2988842901
crypto pki certificate chain TP-self-signed-2988842901
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32393838 38343239 3031301E 170D3134 30333134 31383434
31305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 39383838
34323930 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100BA89 6AA1AB57 88B8B2D5 CCFA8F79 8FA16412 6216EE12 D35FE0CD 970AF350
D171D212 934C771B EFE57229 B1B654E8 9B9C7BE6 3753C3B9 09B2D27E ABC63CAC
488594BD B31E0C66 0E1EE573 897D6C2E 3E958037 57865387 BD94701A 6AA0B05C
840AF33D 12169BBF 26BCE327 2E056B5E 5DEEF22B BD8F9BF9 25A18514 02FF2874
B7950203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14AD838B BC007C82 1853A39A 3A5ADEC4 263E18BC 57301D06
03551D0E 04160414 AD838BBC 007C8218 53A39A3A 5ADEC426 3E18BC57 300D0609
2A864886 F70D0101 05050003 81810057 94765DF7 DF67928E 15777F17 B533A9E1
1560BB6C 3841D11B EE6CAB6C A86CBD4F 2CE1B2AC E636253E 3C1915F0 A1FE88C5
917D41FA 65CD95E5 F277B411 1814AE2D F9FF6757 CF742C33 DADB97B6 9FF31327
562315D5 0A64A9F4 0566DBCC 25397E34 01A15316 4F2B5720 CDA249D8 3382B4E7
09237C96 5AA11824 15223295 1C16BB
quit
ip cef
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip domain name ced.corp.cummins.com
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
voice call send-alert
voice service pots
fax rate disable
voice service voip
fax protocol none
h323
modem passthrough nse codec g711alaw
voice class h323 1
h225 timeout tcp establish 3
h225 timeout setup 2
voice class custom-cptone jointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice class custom-cptone leavetone
dualtone conference
frequency 400 800
cadence 400 50 200 50 200 50
voice hunt-group 2 parallel
list 5804,5838,5875,5877
pilot 1002
voice hunt-group 3 parallel
list 5802,5829,5830
pilot 1003
voice hunt-group 4 parallel
list 5801,5823,5827,5836,5857,5865,5867
pilot 1004
voice hunt-group 5 parallel
list 5806,5822,5848,5863
pilot 1005
voice hunt-group 6 parallel
list 5805,5837,5840,5846,5849,5858,5869,5874,5876
pilot 1006
voice hunt-group 7 parallel
list 5847,5851,5878
pilot 1007
voice hunt-group 8 parallel
list 5882,5803,5808,5810
pilot 1008
voice hunt-group 9 parallel
list 5833,5834,5807,5861,5871
pilot 1009
voice translation-rule 2
rule 1 /251655810/ /5810/
rule 2 /251655812/ /5812/
rule 3 /251655814/ /5814/
rule 4 /251655811/ /5811/
rule 19 /25165581/ /5800/
rule 20 /^25165\(...\)/ /\1/
rule 1 // /00/ type national national
rule 2 // /000/ type international international
voice translation-profile IN
translate calling 10
voice translation-profile INC_DDI
translate called 2
license udi pid C3900-SPE100/K9 sn FOC1801877Y
license accept end user agreement
license boot module c3900 technology-package securityk9
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
file privilege 0
username FrancaCosta password 7 08630E
username DavideFratta password 7 134755
redundancy
controller E1 0/0/0
pri-group timeslots 1-13,16
controller E1 0/0/1
controller E1 0/1/0
controller E1 0/1/1
ip tftp source-interface Loopback100
crypto isakmp policy 10
authentication pre-share
group 2
crypto isakmp key D#m.ngw!9rt address 0.0.0.0
crypto isakmp keepalive 30 5
crypto ipsec transform-set trans10 esp-3des esp-md5-hmac
mode transport
crypto ipsec profile dynVPN
set transform-set trans10
ip address 192.168.255.226 255.255.255.255
ip address 10.255.46.26 255.255.255.255
interface Tunnel1
ip address 192.168.254.226 255.255.255.0
no ip redirects
ip accounting output-packets
ip mtu 1300
ip nhrp authentication dynkey
ip nhrp map multicast 192.158.34.32
ip nhrp map 192.168.254.3 192.158.34.32
ip nhrp map multicast 192.158.36.18
ip nhrp map 192.168.254.2 192.158.36.18
ip nhrp network-id 99
ip nhrp holdtime 300
ip nhrp nhs 192.168.254.3
ip nhrp nhs 192.168.254.2
ip nhrp shortcut
ip nhrp redirect
ip ospf network point-to-multipoint
ip ospf cost 20
delay 1000
tunnel source GigabitEthernet0/2
tunnel mode gre multipoint
tunnel key 100000
tunnel path-mtu-discovery
tunnel protection ipsec profile dynVPN
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Ethernet LAN
ip address 160.95.175.1 255.255.255.192
ip flow ingress
ip flow egress
duplex auto
speed auto
interface ISM0/0
ip unnumbered GigabitEthernet0/1
service-module ip address 172.18.146.5 255.255.255.128
!Application: CUE Running on ISM
service-module ip default-gateway 172.18.146.4
interface GigabitEthernet0/1
description Ethernet VOIP
ip address 172.18.146.4 255.255.255.128
duplex auto
speed auto
interface GigabitEthernet0/2
description ISP Circuit
ip address 82.184.5.62 255.255.255.252
ip access-group DMVPN in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
duplex auto
speed auto
no cdp enable
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface FastEthernet0/2/0
no ip address
duplex auto
speed auto
interface FastEthernet0/2/1
no ip address
duplex auto
speed auto
interface Vlan1
no ip address
router ospf 1
router-id 192.168.255.226
redistribute static metric 1 subnets route-map local-lan
network 10.255.46.26 0.0.0.0 area 51
network 160.95.175.0 0.0.0.63 area 51
network 160.95.218.0 0.0.0.127 area 51
network 160.95.218.128 0.0.0.127 area 51
network 172.18.146.0 0.0.0.127 area 51
network 172.18.146.128 0.0.0.63 area 51
network 192.168.254.0 0.0.0.255 area 51
network 192.168.255.226 0.0.0.0 area 51
distribute-list distributeOut out
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:/GUI
ip flow-export source GigabitEthernet0/2
ip flow-export version 5
ip flow-export destination 160.95.9.202 9999
ip flow-top-talkers
top 20
sort-by bytes
ip route 0.0.0.0 0.0.0.0 82.184.5.61
ip route 160.95.175.0 255.255.255.192 160.95.175.3
ip route 160.95.218.0 255.255.255.128 160.95.175.3
ip route 160.95.218.128 255.255.255.128 160.95.175.3
ip route 172.18.146.0 255.255.255.128 160.95.175.3
ip route 172.18.146.5 255.255.255.255 ISM0/0
ip route 172.18.146.128 255.255.255.128 160.95.175.3
ip access-list standard distributeOut
permit 192.168.254.226
permit 192.168.255.226
permit 10.255.46.26
permit 160.95.218.0 0.0.0.127
permit 160.95.218.128 0.0.0.127
permit 172.18.146.128 0.0.0.63
permit 172.18.146.0 0.0.0.127
permit 160.95.175.0 0.0.0.63
ip access-list standard local-lan-range
ip access-list extended DMVPN
remark Allows DynamicMultiPointVPN
permit udp any any eq isakmp
permit udp any any eq non500-isakmp
permit esp any any
permit gre any any
permit udp any any eq bootpc
permit udp any any eq bootps
permit icmp any any echo-reply
permit icmp any any time-exceeded
permit icmp any any unreachable
permit icmp host 192.158.61.19 any echo
permit icmp host 192.158.36.18 any echo
permit icmp host 192.158.34.32 any echo
deny ip any any
ip radius source-interface Loopback100
access-list 23 permit 172.24.164.4
access-list 23 permit 143.222.204.193
access-list 23 permit 143.222.204.194
access-list 23 permit 143.222.220.240
access-list 23 permit 143.222.173.108
access-list 23 permit 160.95.49.93
access-list 23 permit 146.91.97.25
access-list 23 permit 143.222.223.84
access-list 23 permit 143.222.251.64
access-list 23 permit 143.222.252.67
access-list 23 permit 146.91.6.33
access-list 23 permit 10.187.28.0 0.0.1.255
access-list 23 permit 143.222.52.0 0.0.1.255
access-list 23 permit 143.222.254.0 0.0.0.255
access-list 23 permit 172.26.2.0 0.0.1.255
access-list 23 permit 172.26.253.0 0.0.0.255
access-list 23 permit 160.95.114.0 0.0.0.255
access-list 23 permit 160.95.122.0 0.0.1.255
access-list 23 permit 160.95.222.0 0.0.1.255
access-list 23 permit 192.168.82.0 0.0.1.255
access-list 23 permit 192.168.84.0 0.0.1.255
access-list 23 permit 192.168.86.0 0.0.1.255
access-list 23 permit 192.168.88.0 0.0.1.255
access-list 23 permit 192.168.92.0 0.0.1.255
access-list 23 permit 192.168.94.0 0.0.1.255
access-list 23 permit 192.158.61.0 0.0.0.255
access-list 23 permit 192.158.36.0 0.0.1.255
access-list 23 permit 10.187.30.0 0.0.1.255
access-list 23 permit 10.129.98.0 0.0.0.255
access-list 23 permit 10.187.40.0 0.0.0.255
nls resp-timeout 1
cpd cr-id 1
route-map local-lan permit 10
match ip address local-lan-range
set metric 10
set metric-type type-1
snmp-server community CMPower RO
snmp-server enable traps entity-sensor threshold
tftp-server flash:apps45.9-2-1ES4.sbn
tftp-server flash:cnu45.9-2-1ES4.sbn
tftp-server flash:cvm45sccp.9-2-1ES4.sbn
tftp-server flash:dsp45.9-2-1ES4.sbn
tftp-server flash:jar45sccp.9-2-1ES4.sbn
tftp-server flash:apps37sccp.1-4-4-0.bin
tftp-server flash:SCCP45.9-2-1SR2S.loads
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:List.xml
tftp-server flash:Desktops/320x212x16/CumminsDistribution.png
tftp-server flash:Desktops/320x212x16/TN-CumminsDistribution.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:B016-1-0-4.SBN
radius-server host 143.222.255.1 auth-port 1812 acct-port 1813
radius-server key 7 081645403D110035131F18082F6608272030161B02210213
control-plane
voice-port 0/0/0:15
translation-profile incoming IN
cptone IT
description Voice ISDN
mgcp profile default
dial-peer voice 3890 pots
translation-profile incoming INC_DDI
incoming called-number .
direct-inward-dial
dial-peer voice 101 voip
description Unity
destination-pattern 7...
session protocol sipv2
session target ipv4:172.18.146.5
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1 pots
description DIAL OUT
destination-pattern 0T
port 0/0/0:15
dial-peer voice 2 pots
destination-pattern 6T
port 0/0/0:15
gatekeeper
shutdown
telephony-service
authentication credential CME cummins
max-ephones 120
max-dn 120
ip source-address 172.18.146.4 port 2000
service phone ehookEnable 1
timeouts interdigit 3
system message Cummins Milan
url services http://172.18.146.5/voiceview/common/login.do
url authentication http://172.18.146.4/CCMCIP/authenticate.asp
cnf-file location flash:
load 7916-24 B016-1-0-4.SBN
load 7937 apps37sccp.1-4-4-0.bin
time-zone 23
time-format 24
date-format dd-mm-yy
voicemail 7000
max-conferences 8 gain -6
moh "SUMMERFEELINGS.wav"
web admin system name CME password cummins
dn-webedit
time-webedit
transfer-system full-consult dss
secondary-dialtone 0
create cnf-files version-stamp 7960 Nov 10 2014 16:30:06
ephone-dn-template 1
ephone-dn-template 2
ephone-template 1
type 7945
overlap-signal
ephone-template 2
type 7945
overlap-signal
ephone-template 3
type 7965
overlap-signal
ephone-dn 1 octo-line
number 5800
label Longinotti Monica
name Longinotti Monica
call-forward noan 7002 timeout 15
transfer-mode consult
ephone-dn 2 dual-line
number 5801
pickup-group 4
label Computer Room
name Computer Room
call-forward busy 7000
call-forward noan 7000 timeout 30
ephone-dn 3 dual-line
number 5802
pickup-group 3
label Costanza Gianluca
name Costanza Gianluca
ephone-dn 4 dual-line
number 5803
pickup-group 3
label Foreman
name Foreman
ephone-dn 5 dual-line
number 5804
pickup-group 2
label Bertaggia Elena
name Bertaggia Elena
ephone-dn 6 dual-line
number 5805
pickup-group 6
label Lemmi Cesare
name Lemmi Cesare
ephone-dn 7 dual-line
number 5806
pickup-group 5
label Vignati Alessandra
name Vignati Alessandra
ephone-dn 8 dual-line
number 5807
label Cassuci Franca
name Cassuci Franca
call-forward all 00692730715
ephone-dn 9 dual-line
number 5808
pickup-group 3
label Technicians
name Technicians
ephone-dn 10 dual-line
number 5809
label Corradini Laura
name Corradini Laura
ephone-dn 11 dual-line
number 5810
label Workshop
name Workshop
ephone-dn 12 dual-line
number 5003
label Meeting Room 3
name Meeting Room 3
ephone-dn 13
number 5001
label Meeting Room 1
name Meeting Room 1
ephone-dn 15
number 5002
label Meeting Room 2
name Meeting Room 2
ephone-dn 16
number 5815
label Meeting Room 2 Conf
name Meeting Room 2 Conf
ephone-dn 22 dual-line
number 5821
label Di Pinto Francesco
name Di Pinto Francesco
ephone-dn 23 dual-line
number 5822
pickup-group 5
label Unali Stefano
name Unali Stefano
ephone-dn 24 dual-line
number 5823
pickup-group 4
label Costa Franca
name Costa Franca
ephone-dn 25 dual-line
number 5824
label Caldognetto Viviana
name Caldognetto Viviana
ephone-dn 28 dual-line
number 5827
pickup-group 4
label Alberti Marco
name Alberti Marco
ephone-dn 29 dual-line
number 5828
label Cervini Fabrizio
name Cervini Fabrizio
ephone-dn 30 dual-line
number 5829
pickup-group 3
label Bizzoca Damiano
name Bizzoca Damiano
ephone-dn 31 dual-line
number 5830
pickup-group 3
label Claudio Rossi
name Claudio Rossi
ephone-dn 32 dual-line
number 5831
label Rossi Claudio C
name Rossi Claudio C
ephone-dn 34 dual-line
number 5833
pickup-group 9
label Furore Eleonora
name Furore Eleonora
ephone-dn 35 dual-line
number 5834
pickup-group 9
label Bifulco Umberto
name Bifulco Umberto
ephone-dn 36 dual-line
number 5835
label SPARE 5835
name SPARE 5835
ephone-dn 37 dual-line
number 5836
pickup-group 4
label Midali Silvana
name Midali Silvana
ephone-dn 38 dual-line
number 5837
pickup-group 6
label Gervasio Riccardo
name Gervasio Riccardo
ephone-dn 39 dual-line
number 5838
pickup-group 2
label Giacobazzi Alessandro
name Giacobazzi Alessandro
ephone-dn 40
number 5839
label SPARE 5839
name SPARE 5839
ephone-dn 41 dual-line
number 5840
pickup-group 6
label Prezioso Giovanni
name Prezioso Giovanni
ephone-dn 42 dual-line
number 5841
label Petit Emmanuel Pierre
name Petit Emmanuel Pierre
ephone-dn 43 dual-line
number 5842
label Tardelli Mauro
name Tardelli Mauro
ephone-dn 44 dual-line
number 5843
label Gradara Alberto
name Gradara Alberto
ephone-dn 45 dual-line
number 5844
label Giannino Iolanda
name Giannino Iolanda
ephone-dn 47 dual-line
number 5846
pickup-group 6
label Pasquini Frederich
name Pasquini Frederich
ephone-dn 48 dual-line
number 5847
pickup-group 7
label Ferrari Emanuele
name Ferrari Emanuele
ephone-dn 49
number 5848
pickup-group 5
label De Franceschi Fabio
name De Franceschi Fabio
ephone-dn 50 dual-line
number 5849
pickup-group 6
label Tartamella Fabio
name Tartamella Fabio
ephone-dn 52 dual-line
number 5851
pickup-group 7
label Abbagnano Simone
name Abbagnano Simone
ephone-dn 53
number 5852
label FAX Reception
name FAX Reception
ephone-dn 54
number 5853
label FAX Workshop
name FAX Workshop
ephone-dn 55
number 5854
label FAX Warehouse
name FAX Warehouse
ephone-dn 58 dual-line
number 5857
pickup-group 4
label Fratta Davide
name Fratta Davide
ephone-dn 59 dual-line
number 5858
pickup-group 6
label Albertini Roberto
name Albertini Roberto
ephone-dn 60 dual-line
number 5859
label Prescianotto Marika
name Prescianotto Marika
ephone-dn 61 dual-line
number 5860
pickup-group 8
label Gaddo' Aldo
name Gaddo' Aldo
ephone-dn 62 dual-line
number 5861
ephone-dn 64 dual-line
number 5863
pickup-group 5
label Vaiani Fabio
name Vaiani Fabio
ephone-dn 65 dual-line
number 5864
pickup-group 8
label Danova Pietro
name Danova Pietro
ephone-dn 66 dual-line
number 5865
pickup-group 4
label Passolungo Virginia
name Passolungo Virginia
ephone-dn 68 dual-line
number 5867
pickup-group 4
label Bressanelli Elena
name Bressanelli Elena
ephone-dn 70 dual-line
number 5869
pickup-group 6
label Calzolari Graziano
name Calzolari Graziano
ephone-dn 71 dual-line
number 5887
label Green Number
name Green Number
ephone-dn 72 dual-line
number 5871
pickup-group 9
label Biffi Floriana
name Biffi Floriana
ephone-dn 74 dual-line
number 5873
label Zecchinon Aldo
name Zecchinon Aldo
ephone-dn 75 dual-line
number 5874
pickup-group 6
label Roma Denis
name Roma Denis
ephone-dn 76 dual-line
number 5875
pickup-group 2
label Crespi Tiziana
name Crespi Tiziana
ephone-dn 77 dual-line
number 5876
pickup-group 6
label Lulli Morena
name Lulli Morena
ephone-dn 78 dual-line
number 5877
pickup-group 2
label Codazzi Eleonora
name Codazzi Eleonora
ephone-dn 79 dual-line
number 5878
pickup-group 7
label La Montagna Alessandro
name La Montagna Alessandro
ephone-dn 83 dual-line
number 5882
label Gerace Maria Grazia
name Gerace Maria Grazia
ephone-dn 88 dual-line
number 5887
label Green Number
name Green Number
ephone-dn 90 dual-line
number 5889
pickup-group 8
label Giacci Angelo
name Giacco Angelo
call-forward noan 7000 timeout 10
ephone-dn 91
number 5890
label SPARE ANALOGUE 5890
name SPARE ANALOGUE 5890
ephone-dn 96
number 5895
label FAX Aftermarket
name FAX Aftermarket
ephone-dn 97
number 5898
label CBSIT Test 2
description 00390251655898
name CBSIT Test 2
ephone-dn 98
number 5899
label CBSIT Test
description 00390251655899
name CBSIT Test
ephone-dn 99
number 7740
call-forward all 5810
ephone-dn 101
number 8000....
mwi on
ephone-dn 102
number 8001....
mwi off
ephone-dn 119
number *4357
label HELPDESK
name HELDESK
call-forward all 000441442439034
ephone-dn 120
number *288
label AT&T
name AT&T
call-forward all 6800788990
ephone 1
device-security-mode none
mac-address B000.B4D8.0B2E
username "MonicaLonginotti" password zlx86954
type 7965 addon 1 7916-24
button 1:1 21w49
overlap-signal
ephone 2
mac-address 0008.2FB6.63D7
username "ComputerRoom" password aej76770
type 7945
button 1:2
ephone 3
mac-address 0008.2FB6.6317
username "GianlucaCostanza" password vrn08851
type 7945
button 1:3
ephone 4
mac-address 7426.AC63.29A3
max-calls-per-button 4
username "Foreman" password jqa81470
type 7925
button 1:4
ephone 5
mac-address BC67.1CDD.F9D7
username "ElenaBertaggia" password eyf50521
type 7945
button 1:5
ephone 6
mac-address 0008.2FB6.257D
username "CesareLemmi" password dpp88917
type 7945
button 1:6
ephone 7
mac-address 0008.2FB6.63B4
username "AlessandraVignati" password twi83494
type 7945
button 1:7
ephone 8
mac-address 0008.2FB6.66E9
username "FrancaCasucci" password rwv93534
type 7945
button 1:8
ephone 9
mac-address 0008.2FB6.5FD2
username "Technicians" password npm05883
type 7945
button 1:9
ephone 10
mac-address 0008.2FB6.63BA
username "LauraCorradini" password idh33584
type 7945
button 1:10
ephone 11
mac-address 0008.2FB6.28B6
username "Workshop1" password dni00299
type 7945
button 1:11
ephone 12
mac-address 0004.F2F2.E010
type 7937
button 1:12
ephone 13
mac-address A671.40D8.8003
button 1:96
ephone 15
mac-address 0004.F2F5.0980
type 7937
button 1:15
ephone 22
mac-address 0008.2FB6.FB41
username "FrancescoDiPinto" password ten57241
type 7945
button 1:22
ephone 23
mac-address 0008.2FB6.FB8C
username "StefanoUnali" password ose52523
type 7945
button 1:23
ephone 24
mac-address 0008.2FB6.FBDF
type 7945
button 1:24
ephone 25
mac-address 0008.2FB6.FC33
username "VivianaCaldognetto" password lpp85669
type 7945
button 1:25
ephone 28
mac-address 0008.2FB6.63E8
username "MarcoAlberti" password gdq11988
type 7945
button 1:28
ephone 29
mac-address 0008.2FB6.FB49
username "FabrizioCervini" password gwn22007
type 7945
button 1:29
ephone 30
mac-address 0008.2FB6.FD6F
username "DamianoBizzoca" password hal50804
type 7945
button 1:30
ephone 31
mac-address 0008.2FB6.FB4E
username "ClaudioRossi" password iii58631
type 7945
button 1:31
ephone 32
mac-address 0008.2FB6.654F
username "ClaudioCRossi" password cfg18629
type 7945
button 1:32
ephone 34
mac-address 0008.2FB6.FB64
username "EleonoraFurore" password zzj10491
type 7945
button 1:34
ephone 35
mac-address 0008.2FB6.FBA3
username "UmbertoBifulco" password njt79751
type 7945
button 1:35
ephone 36
ephone 37
mac-address 0008.2FB6.FD24
username "SilvanaMidali" password hrl09127
type 7945
button 1:37
ephone 38
mac-address 0008.2FB6.65B8
username "RiccardoGervasio" password dyp99322
type 7945
button 1:38
ephone 39
mac-address 7426.AC63.1B56
username "AlessandroGiacobazzi" password dlk54598
type 7925
button 1:39
ephone 41
mac-address 0008.2FB6.FE13
username "GiovanniPrezioso" password eyv74031
type 7945
button 1:41
ephone 42
mac-address 0008.2FB6.63C2
username "EmmanuelPierrePetit" password wjh51527
speed-dial 1 00033298764818 label "Natalia"
speed-dial 2 00033298764903 label "Marie Helene"
type 7945
button 1:42
ephone 43
mac-address 0008.2FB6.6583
username "MauroTardelli" password gdc27513
type 7945
button 1:43
ephone 44
mac-address 0008.2FB6.65BE
username "IolandaGiannino" password nkq43105
type 7945
button 1:44
ephone 45
mac-address 0008.2FB6.63B8
username "AlbertoGradara" password uzs57263
type 7945
button 1:45
ephone 47
mac-address 0008.2FB6.65B1
username "FrederichPasquini" password trd97060
type 7945
button 1:47
ephone 48
mac-address 0008.2FB6.29F4
username "EmanueleFerrari" password kqp28129
type 7945
button 1:48
ephone 49
mac-address 0008.2FB6.FC23
username "FabioDeFranceschi" password opa57428
type 7945
button 1:49
ephone 50
mac-address 0008.2FB6.2BDF
username "FabioTartamella" password bee15439
type 7945
button 1:50
ephone 52
mac-address 0008.2FB6.24F0
username "SimoneAbbagno" password nat44025
type 7945
button 1:52
ephone 53
mac-address A671.40D8.8000
ephone 54
mac-address A671.40D8.8001
button 1:54
ephone 55
mac-address A671.40D8.8002
button 1:55
ephone 58
mac-address 7426.AC63.6C24
type 7925
button 1:58
ephone 59
mac-address 0008.2FB6.65EA
username "RobertoAlbertini" password omn61851
type 7945
button 1:59
ephone 60
ephone 61
mac-address 7426.AC63.9192
username "AldoGaddo" password wlw98734
type 7925
button 1:61
ephone 62
ephone 64
mac-address 0008.2FB6.FB60
username "FabioVaiani" password vzz57205
type 7945
button 1:64
ephone 65
mac-address 7426.AC63.62D9
username "PietroDanova" password afu84053
type 7925
button 1:65
ephone 66
mac-address 0008.2FB6.60BC
username "ViginiaPassolungo" password joa29044
type 7945
button 1:66
ephone 67
mac-address 7426.AC63.3B6B
username "ErnestoRovito" password mjd12832
type 7925
ephone 68
mac-address 0008.2FB6.29F1
username "ElenaBressanelli" password ywg69605
type 7945
button 1:68
ephone 70
mac-address 0008.2FB6.F9CB
username "GrazianoCalzori" password sfn52944
type 7945
button 1:70
ephone 71
mac-address 0008.2FB6.2539
username "GreenNumber" password jns75394
type 7945
button 1:71
ephone 72
mac-address BC67.1CDC.BB44
username "FlorianaBiffi" password ktg86561
type 7945
button 1:72
ephone 74
mac-address 7426.AC63.5ABA
username "AldoZecchinon" password kfx41335
type 7925
button 1:74
ephone 75
mac-address 0008.2FB6.64FA
username "DenisRoma" password bnb06399
type 7945
button 1:75
ephone 76
mac-address 0008.2FB6.2537
username "TizianaCrespi" password prx99777
type 7945
button 1:76
ephone 77
mac-address 0008.2FB6.60FE
username "MorenaLulli" password kcf47121
fastdial 1 00393486563627 name albertini
fastdial 2 00393486563622 name graziano
fastdial 3 00393406748560 name gervasio
type 7945
button 1:77
ephone 78
mac-address 0008.2FB6.6105
username "EleonoraCordazzi" password vqm92932
type 7945
button 1:78
ephone 79
mac-address 0008.2FB6.6108
username "AlessandroLaMontagna" password wvx26677
type 7945
button 1:79
ephone 83
mac-address 7426.AC63.BC79
username "MariaGraziaGerace" password vwt95056
type 7925
button 1:83
ephone 88
ephone 90
mac-address 7426.AC63.1496
username "AngeloGiacci" password rom41054
type 7925
button 1:90
ephone 91
mac-address A671.40DF.0000
button 1:91
ephone 92
ephone 93
ephone 94
ephone 95
ephone 96
mac-address 0004.F2F2.ED5E
button 1:13
ephone 97
mac-address ECF4.BB63.29F0
type 7945
button 1:97
ephone 98
mac-address 64D8.14A4.BF0A
username "vinny"
type 7945
button 1:98
voice-gateway system 1
network-locale IT
type VG204
mac-address FDEA.6714.0D88
voice-port 0-3
create cnf-files
voice-gateway system 2
network-locale IT
type VG204
mac-address F4EA.6714.0DF0
voice-port 0-3
create cnf-files
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you want to
use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
password 7 14141B180F0B
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 195
no exec
transport input all
stopbits 1
line vty 0 4
access-class 23 in
password 7 01214205155C482C341D
transport input telnet ssh
line vty 5 15
access-class 23 in
scheduler allocate 20000 1000
ntp server 160.95.50.1
ntp server 143.222.1.1
ntp server 160.95.56.253
end
cdmilanucrtr#
12-15-2014 08:33 AM
Hi.
Ok let's try this
rule 1 /^58\(..\)/ /02251655\1/
voice translation-profile OUT
translate calling 100
translation-profile out OUT
Try it an let me know.
Please also attach the output of a debug isdn q931 during an outgoing call
thanks
Carlo
12-15-2014 08:42 AM
Hi Carlo
Thank you for your help
I tried your config but it did not change anything
This is the output of the debug
cdmilanucrtr#debug isdn q931
debug isdn q931 is ON.
cdmilanucrtr#term mon
cdmilanucrtr#
082297: Dec 15 17:39:42 UTC: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 0225165599
082298: Dec 15 17:39:42 UTC: ISDN Se0/0/0:15 Q931: Sending SETUP callref = 0x1118 callID = 0x907E switch = primary-net5 interface = User
082299: Dec 15 17:39:42 UTC: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x1118
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838C
Exclusive, Channel 12
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '0225165599'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '00447825943938'
082300: Dec 15 17:39:42 UTC: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8 callref = 0x9118
082301: Dec 15 17:39:48 UTC: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x9118
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
082302: Dec 15 17:39:55 UTC: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x1118
Cause i = 0x8090 - Normal call clearing
082303: Dec 15 17:39:55 UTC: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x9118
082304: Dec 15 17:39:55 UTC: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x1118
12-15-2014 08:48 AM
Sorry.
Wrong config :(
Carlo
12-15-2014 08:51 AM
Hi Carlo
Yes I noticed it when I looked a bit closer after I replied. I tried
rule 1 /^58\(..\)/ /02516558\1/
It worked!! I really need to learn more about translation rules.
Many Thanks
12-15-2014 09:00 AM
Hi.
Glad to help
Carlo
