1126
reg_cisco
Beginner
Digits dropped when a phone is forwarded
Hello everybody.
I have a strange issue in my CUCM 8.5 cluster (one publisher and one suscriber). I try to expain:
We have with ISP a numbering plan to have short numbers in corporative mobiles. For instance, to dial the 666666667 inside the company, it's enough to dial 29654.
When you call from any of these mobiles to any Cisco phone forwarded to any of mobile short number, one digit is dropped. Only in this scenario.
For example, you dial from 29670 to a Cisco phone forwarded to 29654 and the call goes to 9654 dial number.
The network topologhy is the following:
Call from mobile - ISP - Nortel CS1000 with a DSC -Cisco gateway with a dial peer - CUCM - Cisco phone forwarded - Nortel CS1000 - ISP - Mobile called.
If you call to any short mobile number from any phone which isn't forwarded, everything goes well.
I did several traces and the digit dropped it's shown when the call gets back to Nortel CS100 regarding the topologhy described before, so I'm thinking if CUCM uses a different route pattern when a phone is forwarded.
Thanks in advance.
12 REPLIES 12
Manish Prasad
Contributor
We certainly need to look at CUCM traces to check with other route pattern is matching on the basis of CSS applied to the IP phone dn's Call Forward and Call Pickup Settings section.
Hello.
Thanks for your answer.
CIsco DNA call log:
  • Results Summary
    • Calling Party Information
      • Calling Party = 27707 (short mobile number)
      • Partition =
      • Device CSS =
      • Line CSS = CSS_03-Fijos-Moviles_Nacionales
      • AAR Group Name =
      • AAR CSS =
    • Dialed Digits = 7173 (Cisco dn forwarded)
    • Match Result = RouteThisPattern
    • Matched Pattern Information
      • Pattern = 7173
      • Partition = PT_Usuarios
      • Time Schedule =
    • Called Party Number = 7173
    • Time Zone = Etc/GMT
    • Call Classification = OnNet
    • InterDigit Timeout = NO
    • Device Override = Disabled
    • Outside Dial Tone = NO
  • Call Flow
    • TranslationPattern :Pattern=
      • Partition =
      • Positional Match List = 7173
      • Calling Party Number = 27707
      • PreTransform Calling Party Number =
      • PreTransform Called Party Number =
      • Calling Party Transformations
        • External Phone Number Mask = NO
        • Calling Party Mask =
        • Prefix =
        • CallingLineId Presentation =
        • CallingName Presentation =
      • ConnectedParty Transformations
        • ConnectedLineId Presentation =
        • ConnectedName Presentation =
      • Called Party Transformations
        • Called Party Mask =
        • Discard Digits Instruction =
        • Prefix =
        • Called Number =
    • Directory Number :DN= 7173
      • TypeCFACSSPolicy =
      • Call Classification = Unknown
      • Forwarding Information
        • Forward All : DN = 299990 VoiceMail = No CSS = CSS_03-Fijos-Moviles_Nacionales
        • Forward Busy
          • Internal : DN = VoiceMail = No CSS = CSS_03-Fijos-Moviles_Nacionales
          • External : DN = VoiceMail = No CSS = CSS_03-Fijos-Moviles_Nacionales
        • Forward No Answer
        • Forward No Coverage
        • Forward Unregistered
        • CFDF : DN = VoiceMail = No CSS =
        • Pickup Group Number =
      • Device :Type= Cisco 7942
        • Device Status = Registered
        • Device Name = SEPE23DF3ABD8C7
        • Ignore Presentation Indicators = Disabled
        • Logged Into Hunt Groups = Enabled
        • Alerting Name = Jose
        • Dual Mode = Disabled
        • Do Not Disturb(DND)
          • DND Status = Disabled
          • DND Option =
          • DND Incoming Call Alert =
        • Automated Alternate Routing (AAR)
          • AAR Group Name =
          • AAR Calling Search Space =
          • AAR VoiceMail Status = Disabled
          • AAR Destination Mask =
          • AAR Prefix Digits =
  • Alternate Matches
    • Partition :Name= PT_Nortel
      • Pattern
        • Pattern = 7XXX
        • Pattern Type = Enterprise
        • Call Classification = OffNet
        • CallManager Device Type = AccessDevice
        • PatternPrecedenceLevel = PlDefault
        • PatternRouteClass = RouteClassDefault
    • Partition :Name= PT_Usuarios
      • Pattern
        • Pattern = 7XXX
        • Pattern Type = Translation
        • TranslationPartition = [d3c62c90-d6b4-be5b-1bf0-6f8e91934e33]
        • RouteNextHopByCgpn = false
If you need anymore, just let me know.
Thanks in advance.
Suresh Subramanian
Rising star
Please check the call forward CSS on the phone configuration. You may also run the Dialed Number Analyzer with that CallFoward CSS and dialed digit should be 29654.
If you call 29654 from the cisco phone, does it work?
Also check the gateway debugs to verify whether or not the complete number is received from CUCM to gateway.
please collect debug voice ccapi inout for a test call from the gateway and let us the calling mobile, called cisco phone number and the final mobile destination number. If not the complete running configuration, Pleas include the relevant configurations from gateway.
//Suresh
Please rate all the helpful posts
//Suresh Please rate all the useful posts.
Hi, can you get the same DNA logs with calling number: 7173 & called number: 299990?
  • Results Summary
      • Calling Party = 020???
      • Partition =
      • Device CSS =
      • Line CSS = CSS_04-Internacionales
      • AAR Group Name =
      • AAR CSS =
    • Dialed Digits = 29990
      • Pattern = 2[4-9]XXX
      • Partition = PT_Moviles-Nacionales
      • Time Schedule =
    • Called Party Number = 29990
    • End Device = RL_Nortel
  • Call Flow
      • Partition =
      • Positional Match List = 29990
      • Calling Party Number = 020???
        • Prefix =
        • Prefix =
        • Called Number =
    • Route Pattern :Pattern= 2[4-9]XXX
      • DialPlan =
      • Route Filter
        • Filter Name =
        • Filter Clause =
      • Require Forced Authorization Code = No
      • Authorization Level = 0
      • Require Client Matter Code = No
      • PreTransform Calling Party Number = 8555
      • PreTransform Called Party Number = 29990
        • External Phone Number Mask = YES
        • Calling Party Mask = XXXX
        • Prefix = 020
        • CallingLineId Presentation = Default
        • CallingName Presentation = Default
        • ConnectedLineId Presentation = Default
        • ConnectedName Presentation = Default
        • Discard Digits Instruction = None
        • Prefix =
        • Called Number = 29990
    • Route List :Route List Name= RL_Nortel
      • RouteGroup :RouteGroup Name= RG_Nortel
          • External Phone Number Mask = Default
          • Prefix =
          • Discard Digits Instructions =
          • Prefix =
          • Called Number =
        • Device :Type= H323Gateway
          • End Device Name = 10.68.20.1
          • PortNumber = 0
          • Device Status = UnKnown
          • AAR Group Name =
          • Inbound Fast Start = Disabled
          • Outbound Fast Start = Disabled
          • Call Classification = Use System Default
          • Tunneled Protocol = None
            • Calling Party Selection = Originator
            • Calling Party Presentation = Allowed
            • CallerID DN =
  • Alternate Matches
    • Note: Information Not Available
Hi Suresh.
You can see Cisco DNA log.
If you call 29654 directly, everything goes well.
debug voice ccapi inout log for a failling call (calling from 27707 to 8555 forwarded to 29057):
May 28 10:26:13.603: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
May 28 10:26:13.603: :FEATURE_VSA attributes are: feature_name:0,feature_time:1230032704,feature_id:559629
May 28 10:26:13.603: //559629/5420A86F8134/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
May 28 10:26:13.603: //559629/5420A86F8134/CCAPI/ccCallSetContext:
   Context=0x4BD03638
May 28 10:26:13.607: //559629/5420A86F8134/CCAPI/cc_api_call_connected:
   Interface=0x4893F3A4, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Please Suresh, tell me the exact configuration you want to check in my gateway
It seems the complete called number is coming in to the gateway. To confirm the same, please collect the debug voice ccapi inout & debug isdn q931 for the call failure and provide us the complete log. Also please collect same set of debugs for a test call from IP phone to same mobile number.
we need to check the dial-peer configuration and translation rules if configured any. you may also post the complete running configuration if you are ok.
//Suresh
You can see above the voice ccapi debug for the call failure.
When you enable debug isdn q931 traces, the failure call doesn't appear.
I have a problem: I can't post here all running configuration, you know, it is a corporate voice gateway. If you tell me how, I'll show you any part of configuration.
Thanks.
Is this issue permanent or intermittent? The above posted debug will not help. You should collect the complete logs for the call failure. Please post the dialpeer configurations too.
It happens the same to all Cisco phones.
Excuse me Suresh. I don't know how to collect the traces and the dial-peer configurations. I will be very pleased with you if you help me.
Sure, you can enter the command 'show run | be dial-peers'. It will display the configurations starting from dial-peers only. you can copy and paste it here.
For collecting the debugs, you can follow the below steps.
Recommended Configuration:
Router(config)# service sequence-numbers
Router(config)# service timestamps debug datetime localtime msec
Router(config)# logging buffered 10000000 debug
Router(config)# no logging console
Router(config)# no logging monitor
Router(config)# default logging rate-limit
Router(config)# default logging queue-limit
Router(config)# voice iec syslog
<Enable debugs, then wait for issue to occur.>
<Enable session capture to txt file in terminal program.>
Router# terminal length 0
Router# show logging
>> you can also refer this document on how to collect the logs
URL: https://supportforums.cisco.com/document/62906/how-properly-and-safely-collect-debugs-ios-router#
Thanks a lot for your help Suresh.
Finally, I detect a a issue with operator and It is solved now.
Create
Recognize Your Peers
Content for Community-Ad
