Community Helping Community
111
Highlighted
Beginner
Direct inward dial setup
We're setting up an extension that needs direct inward dial, but it doesn't seem to be working.  Is this enabled in the call manager or is it something that needs to be set up with our phone company?
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Cisco Employee
Re: Direct inward dial setup
And I just finished adding this question to my FAQ a few minutes ago
http://docwiki.cisco.com/wiki/CUCM_Dial_Plan_and_Call_Routing_FAQ#How_do_you_configure_a_DID_in_CUCM.3F.3F
java
if this helps, please rate
2 REPLIES 2
If you have a DID from your Telco and want it to map 1:1 on a phone or for a specific user, 2 simple options -
1. Assign the 10/11 digit DID as an extension on the phone.
2. If the users have "n" digits as their extensions, you can use a TP to translate the DID to the "n" extension. Ensure your CSS/Partition are in place correctly.
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
java
Content for Community-Ad
FusionCharts will render here
