Direct line FXO port configuration
I am using CME router 2921.I have 2 FXO card (4 ports) and 8 PSTN lines are  connected to my router. how to configure one line direct manager phone.
router running configuration example..
ephone-dn  45
number 267
description GM
name GM-Guest
call-forward busy 999
call-forward noan 999 timeout 15
trunk group fxo
voice-class cause-code 1
hunt-scheme longest-idle
voice-port 0/0/0
trunk-group FXO
supervisory disconnect dualtone mid-call
supervisory custom-cptone STC
input gain 14
timeouts initial 0
timeouts interdigit 2
timeouts call-disconnect 3
timeouts ringing 5
timeouts wait-release 3
connection plar 888
caller-id enable
voice-port 0/0/1
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/0/2
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/0/3
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/1/0
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/1/1
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/1/2
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
voice-port 0/1/3
trunk-group FXO
input gain 14
timeouts initial 0
timeouts ringing 5
connection plar 888
caller-id enable
dial-peer cor custom
name internal
name local
name national
name mobile
name international
dial-peer cor list internal
member internal
dial-peer cor list local
member local
dial-peer cor list national
member national
dial-peer cor list mobile
member mobile
dial-peer cor list international
member international
dial-peer cor list Restricted
member internal
dial-peer cor list LocalCalls
member internal
member local
dial-peer cor list LongDistance
member internal
member local
member national
member mobile
dial-peer cor list International
member internal
member local
member national
member mobile
dial-peer voice 1 pots
trunkgroup FXO
corlist outgoing local
destination-pattern 9[19]..
forward-digits 3
dial-peer voice 2 pots
trunkgroup FXO
destination-pattern 9[2-8][0-9][1-9]....
forward-digits 7
dial-peer voice 3 pots
trunkgroup FXO
corlist outgoing mobile
destination-pattern 905[056].......
prefix 05
dial-peer voice 4 pots
trunkgroup FXO
corlist outgoing national
destination-pattern 90[234679].......
prefix 0
dial-peer voice 5 pots
trunkgroup FXO
corlist outgoing international
destination-pattern 900T
prefix 00
dial-peer voice 6 pots
trunkgroup FXO
destination-pattern 9600T
prefix 600
dial-peer voice 7 pots
trunkgroup FXO
destination-pattern 9800T
prefix 800
7 Replies 7
Marwan Urabi
under voice-port 0/x/x  (direct line you want)
connection plar xxx (GM dn number)
regards
Marwan
Thanks dear....
Hi Muhan,
You need to use Connection Plar. For example, when a call  comes in on this line it is forwarded to 1001.
voice-port 2/1/0
connection plar opx 1001
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
My problem solved.......thankyou my friend...
Why such a low rating givem to a 100% correct answer above?
That must never be done, as it is nothing less than offensive.
I've rated Leo's post again to partially compensate.
Thanks Paolo
Marwan Urabi
I make 1st correct answer !!!!
