Disable 9971 select button LED while phone is in power-save mode
andrew.schaefer
Some of our IP phones are located in bedrooms and at night when the phone goes into power-save mode, the select button LED lights up. It is bright enough to light up the room and cause people to complain. Is there any way to disable this LED from illuminating when the phone goes into power-save mode?
19 Replies 19
Wish this feature existed for 3PCC firmware. Seems it’s only in the enterprise firmware.
Could i have the right Parameter for sep.cnf to disable Mode Button Led?
best regards
Paddy
Hi Jamie,
Do you know whether this feature will come to 3PCC handsets? I have the 8861-3PCC-K9 on 11.3.2 and it would be great if an option to turn off all LEDs (including the white circular select button) in power save mode. Even better, an option to disable the LEDs across a given time period, eg. 1900-0700.
Many thanks!
Any plans for bringing this feature to 3PCC ?
Please consider also adding this feature to 3PCC.
