Disable Divert
Is there a way to disable the Divert option on 8945 and 7841 phones?
shh5455
Level 3
Level 3
Yes, remove it from the soft key template during the Ring In state.
shh5455
Level 3
Level 3
Thank you for the quick response. This seems to be the correct answer to my problem. The next problem is... how to actually edit the Soft Key Template. I am reading through some guides... but I wish Cisco would make this type of thing easier.
Oh yeah.  They do try to hide that.  In the upper right hand corner is a drop down menu.  Configure Softkey Template is there.
You were right on the money again. Thank you so much!
