disable/remove missed call delete option from phone settings
Anukalp S
Hi, please confirm if it is possible to disable or remove softbutton to delete missed call from phone settings, i have been running CUCM 10x and want to disable it on phone 9971
Georgios Fotiadis
Unfortunately not. This is embedded is the corresponding application and can not be altered.
Georgios
Please rate if you find this helpful.
