Disable vad on 7912 cisco phone
marc.autret
I have got a voice detection trouble with my 7912 cisco phone, is there a way to manage the voice detection or to disable it without cisco call manager (my cisco phones are all running with the sip protocol).
Thnak you very much for your answer.
Best regards
Philippe delimen
gogasca
Level 10
Level 10
Hi Philippe
Please refer to the followling description and the URL for the document,
VAD configuration can be configured through the 'audiomode' parameter:
# Parameter: AudioMode
# Type: bitmap value
# Description: Used for controlling or fine-tuning certain audio features #
# Options: Bit Values
# 0 Silence Suppression in G.711
# 0 = Disable silent suppression in G.711
# *1 = Enable silence suppression in G.711
# 1-3 RESERVED. Must be set to 0.
# 4-5 DTMF Transmission Method
# 0 = Always inband
# *1 = Negotiated via SDP
# 2 = Always out-of-band
# 6-31 RESERVED. Must be set to 0.
# Defaults are marked with *.
AudioMode:0x00000011
See also:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_ipphon/english/ipp79
05g/addprot/sip/7905sch8.htm#wp1075121
I hope this can answer your question.
Thank you for your answer, but it did not fix my phone trouble. In fact, i have to disable voice detection in order to always let the voice pass through the phone.
At the moment, when i call an extension with my sip 7912 phone and the called person has answered, i do not hear his voice. I have to talk in my 7912 phone to establish the communication, and then everything goes nice.
So, i would like to shutdown voice detection or change the voice detection threshold.
regards.
Philippe.
The info (excellent as always) provided by gogasca indeed it is telling you how to disable VAD by the use of a configration file. You will a small package on (available to CCO registered users) that contains an utility used to generate the binary config, a tagging file needed by the same. Also incuded, bmp to logo utility.
Hi all, and thank you for you help.
I found the soluce by making changes to my configuration file. I post it here so that it can help someone else ;-)
----- cut here -----
#txt
UIPassword:
upgradecode:3,0x601,0x0400,0x0100,,69,,
dhcp:1
Proxy:
UID:
PWD:
LoginID:
UseLoginID:1
SIPPort:5060
SIPRegInterval:3600
SIPRegOn:1
AudioMode:0x00000010
NumTxFrames:2
ConnectMode:0x00000010
TimeZone:20
NTPIP:
UseTftp:1
CfgInterval:60
TraceFlags:0x00000000
DialPlan:911|1>#t8.r9t2-|0>#t811.rat4-|^1t4>#.-
RingOnOffTime:2,4,25
DialTone:2,31538,814,30831,2032,0,0,0,0,0,0
DialTone2:2,30743,1384,29864,1252,0,0,0,0,0,0
BusyTone:2,30467,1104,28959,1404,1,4000,4000,0,0,0
ReorderTone:0,2,30467,1104,28959,1404,0,0,1,2000,2000,0,0,0,0,0,0
RingBackTone:2,30831,2032,30467,1104,1,16000,32000,0,0,0
CallWaitTone:1,30831,2412,0,0,1,2400,2400,0,0,4800
MediaPort:16384
SigTimer:0x00000064
VoiceMailNumber:
DisplayName:
ShortName:0
TimeFormat:h:ia
DateFormat:m/d/y
CallWaiting:1
AttendedTransfer:1
BlindTransfer:1
Conference:1
