04-14-2013 01:05 AM - edited 03-16-2019 04:47 PM
Someone help me on how to disable email notification for a single user from Unity. User receives email notification with .wav file from unity. He wants us to disable that.
Note: Users are exported from Exchange Server. User has no access to Unity Personal Assistant.
Steps I tried:
Logged in to Unity as a admin.
Searched and selected the Subscriber Profile - > Clicked Message Notification -> Under Notification devices, selected Text for Unity -> Unchecked Voice Message and everything.
Did the same on Home Phone to Work Phone. But still he receives email notification
Awaiting your suggestions
R. Sre Hari
+971557000997
04-14-2013 05:55 AM
Are you saying the user is receiving a Message Notification in addition to the actual voicemail message in Exchange; or, only one email per voicemail?
If the later this is how Unity Unified Messaging worked: the user's Exchange mailbox was used as the message store for voicemails. If Unity was deployed as a Voicemail Only solution instead of UM a local copy of Exchange was installed on the Unity server instead of joining your Exchange organization. In short, Unity relies on Exchange.
Your options:
Please remember to rate helpful responses and identify helpful or correct answers.
04-14-2013 07:04 AM
Hi Jonathan,
User receives one email per voice mail. When we leave a voice message to the user, the MWI is not turning ON on his phone, instead he receives email with .wav(Voice mail) attachment.
User says that he doesnt want email. He wants MWI to be ON on his phone, when someone leaves him a voice mail.
R. Sre Hari
04-14-2013 07:24 AM
Hello
I hope you firstly to dial MWI on ext and MWI off to check it is ok or not .
1- On the Windows Start menu of the Cisco Unity server, click Programs > Cisco Unity > Manage
Integrations.Check that you enter MWI on & Off Subscribers > Subscribers > Messages page for the
subscriber.
2-Confirm that the Use MWI for Message Notification check box is checked.Under MWI Extensions, confirm that the Extension field is set to X (indicating the primary extension assigned to a subscriber) or to the extension number on which MWIs will be set for the subscriber.
Thank you
please rate if this will help
04-14-2013 09:20 AM
i tried dialing MWI On and OFF ext and its working fine. I resynced MWI too. MWI field is set to X.
R. Sre Hari
04-14-2013 09:34 AM
when someone leaves voice message, the MWI on IP phone is not getting ON and the user gets voice mail in a .wav format via email
