disconnect call if MoH activated for certain amount of time.
PatelKunjal
Is there a way to disconnect call on CUCME 8.6 if call was on hold for certain amount of time.  We had situation where someone place call on hold and call wasn't ended on either side, and music on hold was going on all night.
Thank You in advance
Jaime Valencia
Chage this CUCM service parameter: Maximum Hold Duration Timer
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
PatelKunjal
This is for CUCME....is there a similar parameter in CUCME.
Thank you for reply.
