Disconnect Cause=47 error
citytelkhv
Hi, if anyone's familiar with this, please help out:
Call from:
Telco ====>h323====>CME====>IVR Cue
on the inbound leg getting a DC=47 error and the call doesn't go anywhere.
Any ideas?
thanks
Great, glad I could help!  If you found a post to be helpful please rate them.
Chris
6 Replies 6
clileikis
Level 7
Level 7
Hi Daniel,
You usually see that when you attempt to use a resource such as a transcoder/MTP that isn't available.  Check to make sure you don't have a codec mismatch, chances are you're using G711 to the IVR queue so you may want to make sure you hard code your dial-peers to G711 as they're G729 as default.
HTH,
Chris
Chris, I am indeed using a 711 to the IVR, but when I hardcode the 711 to the telco, just get a fast busy, as telco doesn't accept 711 codecs... hmmm?? should I try coding 729br to the IVR?
Hi Daniel,
You have a codec mismatch.  If your provider is sending G729 then you'll need a transcoder to be able to talk to your IVR as its using G711.  Chances are your IVR only supports G711, assuming you're using a CUE module or UCCX.
HTH,
Chris
seems you're right... tried changing the codec to 729br on the IVR leg and got a DC=65... hmmm... ok.. so need to try to invoke a transcoder, never done that before... should be fun it's a UC540 IVR
thnx
Chris
Found this example of invoking a transcoder:
voice-card 0
dspfarm
dsp services dspfarm
sccp local FastEthernet0/0
sccp ccm 10.1.11.4 identifier 1
sccp
sccp ccm group 1
associate ccm 1
associate profile 1 register mtp0013c3443150
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
codec g729r8
maximum sessions 2
associate application SCCP
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 4
sdspfarm tag 1 mtp0013c3443150
issue that i'm having is that I already have the sccp ccm associated with loopback0;
is that correct? if I use this example, it clearly shows that I have to associate with a physical interface?
please help
