Disconnect cause 500 Disconnect cause 41
sweetsaif999
Can any body suggest a solutin for this error :Disconnect cause 500 Disconnect cause 41
what i need to check or configure
odaijeriss
hi mate,
on which device you are getting these codes, also could you please attach the traces or debugs in which you saw this. and if it is IOS based could you please attach the running configurations.
Best Regards,
Odai Jeriss
