Disk Usage climbing
Mohamed Biyas
In Rtmt, Disk Usage>Common shows 77+
Can someone please suggest how to get this value down?
Deepak Mehta
You can delete the trace files from the server to bring disk usage down.
Check below option while collecting log files and it will delete them from the server.
Also you can set file size and number on trace configuration- Servicability page to a lower value so that it gets purged quickly and doesn't fill the disk
Thanks for the prompt response Deepak. I will try it and let you know the result some time later.
Thanks again!
Biyas
