02-27-2012 01:36 AM - edited 03-16-2019 09:47 AM
I am using call manager 7.x and integrting with a thrid party legacy PBX, that PBX system is forwarding digits but not caller name, can I load persoanl address book on all phone sets so when user get call from PBX system, it will translate phone number to caller name and dispaly the caller name instead of phone number.
Or is there any other solution?
Hassan.
02-27-2012 02:53 AM
Hi Hassan
Unfortunately not. This is not something that CUCM does natively which is a shame as it is something that CUCME has been able to do for many years.
If your gateway is configured as H.323 then there is a Cisco supplied TCL script that can perform this function.
HTH. Barry
02-27-2012 03:33 AM
For H3.23 integration, a card is requried, that is not available for that PABX in the market, really its make life difficult and required such intelligent feature, that can solve a lot integration issues with thrid party exachanges, using BAT tool we can load address books on phone sets or through outlook or active directory synshronization, we could get our objective, in fact we need a feature like mobile phone, where adress book works for us.
02-27-2012 07:03 AM
What is meant as 'having H.323', is that you you use H.323 or SIP between CM and GW, not PABX.
I'm not sure about the cisco script (which one, Barry?) however my script for the purpose (number2name) can be acquired at www.ciscoscripts.com
02-27-2012 07:54 AM
02-27-2012 08:57 AM
Thanks, I had never seen it before...
names are configured as service parameters.. doesn't appears to be very scalable
02-27-2012 10:32 AM
Hi Paolo
Yes, you're right. It's pretty ugly to configure and "out of the box" can only support (from memory) 200 names. I did hack the script to increase this, and I also had to write my own script to generate the service parameters in the correct format.
It also seems to create an issue if the target number you are dialling is at the other end of a SIP trunk from CUCM. I'm not sure why, but the call gets rejected. I've never really had the time to look into why.
Barry
02-27-2012 09:55 AM
Hi Barry,
Do you have a link to the site - I have tried searching CCO and Googling without success.
02-27-2012 10:35 AM
Hi James
Looks like it's (yet) another link that has been broken with the new code download process on CCO.
It used to be at www.cisco.com/cgi-bin/tablebuild.pl/tclware
This doesn't exist any more though.
I've got a (slightly old) archive of the TCL scripts. PM if you want a copy.
HTH. Barry
