Display number in outgoing call
Hi!
I need help to find out if it's possible to configure a displayed number eg 5555-551766 (this is a DID configure with num-exp) for outgoing call.
When users make external calls the displayed number is 5555-551700 and when customer wants call back our agents they can use the 5555-551766 number.
I'm trying to fix in 'Calling Party Transformations' in route pattern configuration but it wasn't works.
I put this in the 'Route Patterns' wasn't works.
Next I put this in the 'Directory Number' but still wasn't works.
The version of CUCM is 11.0.1.22900-14
I hope you can help me!
Post removing the commands, I don't see any issue now. Here is the SIP INVITE being sent to the ITSP. "From"/"Contact" headers have the correct info -
May 23 00:36:36.043: //1914897/0D944B000001/SIP/Msg/ccsipDisplayMsg:Sent: INVITE sip:0445555555513@X.X.X.27:5060 SIP/2.0Via: SIP/2.0/UDP X.X.X.226:5060;branch=z9hG4bK4223F941From: "Bad guy" <sip:5555551766@X.X.X.226>;tag=4FF17C20-15D3To: <sip:0445555555513@X.X.X.27>Date: Wed, 23 May 2018 00:36:36 GMTCall-ID: 2EEAA79F-5D5811E8-BE97A33D-347B5593@X.X.X.226Supported: 100rel,timer,resource-priority,replaces,sdp-anatMin-SE: 1800Cisco-Guid: 0227822336-0000065536-0000074230-0169087404User-Agent: Cisco-SIPGateway/IOS-15.5.3.M3Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTERCSeq: 101 INVITETimestamp: 1527035796Contact: <sip:5555551766@X.X.X.226:5060>
Talk to your ITSP. Are they looking for a RPID/PAI as well ?
17 Replies 17
Jaime Valencia
Make sure you're hitting that RP and debug your GW to find out if you're sending the ANI you want or not.
java
if this helps, please rate
Debugged my GW, this is the file with the result. I'm not sure about nothing of this.
Check dial-peer 10 on your GW. Does it have a translation ?
Incoming Leg, the ANI is correct. Once the outgoing leg is created, the ANI is being changed. Attach your router config is possible.
This is my configuration.
The dial-peer 10 doesn't have a translation
Ok. Your dial-peer 31 is configured with "clid network-number 5555551700" command which is overriding the ANI. Remove that command and then test. It should correct the ANI.
It wasn't works. I don't know if I missed something
Did you remove the command ?
Yes, I did it
Remove the network-provided command as well. I guess I missed that in my previous post.
This is my configuration:
R1#show run | section dial-peer voice 31 voip
description **OUTSIDE_TO_CELULARES**
translation-profile outgoing salida
destination-pattern 904[4-5]..........
session protocol sipv2
session target ipv4:x.x.x.x
voice-class sip dtmf-relay force rtp-nte
no voice-class sip outbound-proxy
dtmf-relay rtp-nte
codec g711ulaw
... didn't function
Take a log with the following enabled -
debug ccsip message
debug voice ccapi inout
debug voip translation
Here are the information.
By the way, thank you for help me.
My service provider fixed it. Thank you for all your help!!
