05-09-2023 01:46 PM
The Spectrum voice engineer said the Division header(highlighted below) that Cisco phone system sent to spectrum. This header is causing the problem on their systems. Thus, their system are rejecting the calls. After the Division header removed, all the call forwarding will be working. I can not find Clusterwide Parameters (System - Call Forward) under Service Parameter to remove the Division header. I am on CUCM 10.5.
Could someone help?
Thank you!
05-09-2023 02:01 PM - edited 05-09-2023 02:07 PM
You may find your answer at https://community.cisco.com/t5/ip-telephony-and-phones/diversion-header-for-outbound-call-forward-all-calls/td-p/2959514
or https://community.cisco.com/t5/ip-telephony-and-phones/sip-trunk-diversion-header-issue/td-p/2641764
You can remove diversion header from SIP Trunk configuration in CUCM (disable/uncheck Redirecting Diversion Header Delivery - Outbound), LUA / SIP normalization Script applied to SIP Trunk in CUCM ***, or SIP profile configured on your CUBE (or SBC) if you have one between your CUCM and Spectrum.
*** https://community.cisco.com/t5/call-control/sip-normalization-script-to-add-diversion-header-based-on/td-p/3525269
05-09-2023 03:00 PM
05-09-2023 02:10 PM - edited 05-09-2023 02:24 PM
More information about SIP Normalization Script - https://community.cisco.com/t5/collaboration-videos/a-guide-to-sip-normalization-on-cucm-and-lua-scripting/bc-p/3099495
05-09-2023 02:21 PM
Call forwarding failing because you are sending Diversion Header? Interesting. After a second thought... I worked with Verizon and other service providers before and we usually need to send the diversion header if the From number is not from one of the numbers we own or have configured with their services. I jump to the conclusion you have a SIP Trunk configured with Spectrum. Can you please share how your SIP Trunk is configured? Do you have a CUBE or SBC between your CUCM and Spectrum?
05-09-2023 02:59 PM
