09-12-2017 05:03 AM - edited 03-17-2019 11:09 AM
Hello!
Could you please help me with such question:
I have a router 2921 with PVDM3-32 module, 2 VWIC3 1 port E1 modules, I want to configure 2 E1 ports, can I configure one E1 port with pri-group timeslots 1-10,16 and the second one with pri-group timeslots 1-20 for example. Can I divide my PVDM-32?
Will this configuration work?
Thanks a lot!
Solved! Go to Solution.
09-12-2017 05:36 AM
Yes you can as long as your dsps are not been used by any other resources such as transcoders, mtp or CFB
Please refer here for a better understanding on dsp credit allocation
09-12-2017 05:36 AM
