DMA Error during CUCM Upgrade from 4.1(3) to CUCM 6.0
shoaib.usmani
hello,
I am trying to upgrade CUCM from 4.1(3) to 6.0. When I install DMA 6.0(1)a to CUCM4.1(3), after installation I am not able to open CCMAdmin, DMAAdmin and any other pages. But when I uninstall the Informix Dynamic Server and DMA, the CCMAdmin and other CUCM web pages work fine. Is there something I need to do after installing DMA?
Thanks in advance.
Shoaib.
smalkeric
Level 6
Level 6
You may be hitting with this bug:CSCsl26081. Try rebooting the server.
thanks for your reply. i'm not sure about the bug but i found the fix. The Publisher has to be disconnected from network and things will work fine. although the services like call manager will not start if lan is down but DMA looks for the database not services.
thanks again for your reply.
