DNA shows 0 records
Syed
Level 3
Level 3
Dear All,
I have a device profile for extension mobility. After logging on to a desk phone user is unable to make a particular international call from his line. So, I am trying to do DNA using his line as a directory number in DNA findings, but DNA says 0 records found.
Cannot I do DNA using device profile directory numbers?
Syed
2 Accepted Solutions
Jitender Bhandari
Hi Syed,
We don't have the option of DNA for Extension mobility.
We can go to analyzer and select the CSS which is defined on directory number.
Also see below
https://supportforums.cisco.com/discussion/12251701/extension-mobility-and-dialed-number-analyzer
(Rate if it helps)
JB
Alexey Minaev
You can't perform DNA based on EM profile. You have to  use the phone the user is logged in.
5 Replies 5
Suresh Hudda
Hi Sayed,
If you want to do DNA for EM' profile DN then use "Analysis -> Analyzer" tab. Under phone tab you cant find it as DN not belongs to phone.
Suresh
Thank you all for your quick help & support.
How do I find on which desk phone the user has logged in using his device profile?
Jitender Bhandari
Hi Syed,
Also see below
(Rate if it helps)
JB
Alexey Minaev
