01-10-2008 05:55 PM - edited 03-15-2019 08:10 AM
After a recent upgrade to IOS 12.4(15)T1 & CME 4.1, the DND feature no longer works on any of the phones. The softkey is there, but pressing it does nothing.
Is this a known issue or does anyone have a solution for this? We need the DND key to ensure calls are forwarded while staff are out.
Alternatively, if there is no solution, am I likely to run into problems running CME 4.0 under IOS 12.4(15)T1?
01-12-2008 03:18 AM
Hi, 12.4(15)T1 still has may bugs. Suggest you try 12.4(11)Xj4 thta is CME 4.1 and stable.
01-13-2008 04:00 PM
Bugger. Will try that version some time in the next week after I go through the release notes & feature support.
04-15-2008 10:38 AM
Did you resolve this issue with the DND Softkey. I ran into the same problem after upgrading to IOS 12.4(15)T3.
04-15-2008 08:05 PM
Sorry, haven't resolved this - the usual issue of putting the needs of clients' networks ahead of our own :-)
I expect an IOS version change will probably fix the issue though since the problem wasn't apparent until we upgraded.
04-21-2008 01:39 PM
Thought I would pass this on. Under "Telephony-service" I had to add "hunt-group logout Hlog" After the command is entered you should re-create your "cnf-file" The output says that you should reset your IP Phones but I did not have to. The Dnd softkey begin working right away. I'm running IOS 12.4(15)T3. I hope this helps.
04-29-2008 05:25 PM
Thanks for the info cewilliams. I shall give that a try if the crossgrade to XJ doesn't occur.
