We are running CUCM 8.6 with one publisher and two subscribers. One of the subscribers has failed and we are now running off only one subscriber. In this mode, we are experiencing a number of minor problems with the phones including:
- Time on handsets using incorrect format. (shows as 24hour when it should be 12 hour)
- Phones keep ringing after the extension has beenanswered.
- One-Way voice.
- Calls dropping out when put on hold
- Unable to pickup call when it's put on hold.
Are the phones meant to automatically failover to the other subscriber when one fails? Or do we need to manually reboot the handsets for this to take place?
Also, is all functionality meant to be available when running in the degraded mode?
