10-23-2012 06:24 PM - edited 03-16-2019 01:51 PM
I need Doc for Integrating Panasonic TDA100 and Panasonic KX-TD 12/32 with CUCM 8.6
Appreciate your support
10-25-2012 07:17 AM
And using which itnerface type you would like to do that ?
11-22-2012 02:04 PM
Hi Paolo,
I also need to integrate a Panasonic PANASONIC Ref. KX-TDE100 - Version 5.0, with a CUCM 8.6.2, I'd like to do it with SIP trunks since the Panasonic has the capability to do it.
I do have on my scenario this equipment:
CUP 8.6.2
CUCM 8.6.2
IOS Gateway: Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(2)T1 with voice service voip enabled.
What do you think should work better,
a) Use Gateway as CUBE
c) User CUP as SIP Proxy
Is there any other better solution?
Please let me know your comments and if you have a link for any documentation regarding your answer.
Thks,
05-21-2014 06:14 AM
I need Doc for Integrating Panasonic TDA100 with CUCM 9.x or older
