Does AXL Service Returns the call of IP addres query
Ajay Singh
Can 3rd party applications (such as Resource Scheduler) make call to the Call Manager AXL service in order to find IP Address of a device?
Ajay
William Bell
Ajay,
The AXL/SOAP API is only for config admin functions. It does not provide IP address information. If you are running 3.3(5) - 4.x then you can use devicelistx.asp on the CM.  Which is a simple server-side script that will return a list of devices with IP address, registration status, etc.
If you are running CUCM 5.x or later then you need to use the RISPort API. See here:
http://www.netcraftsmen.net/resources/blogs/good-bye-devicelistx-asp-hello-risport.html
HTH.
Bill
Please rate helpful posts
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
