Does CP7941 support the G.722 codec ?
Chen Wang
Beginner
Beginner
Hi Guys,
I viewed he data sheet of CP7941 IP phone but find no G.722 codec supported on it.
But when I called with 2 CP7941 in LAN, the codec showed on the both phones is G.722.
I believe the codec should negociate between the end points, but why it was G.722 even the endpoints does not support the codec?
Dont it cause by the phone firmware ? The firmware we use is SCCP41.9-2-3S for SCCP phones.
Data Sheet of CP7941
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps6513/product_data_sheet0900aecd802ff012.html
Thanks for the reply in advance.
Chen
The datasheet may not be updated, happens often.
Please remember to rate useful posts clicking on the stars below.
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Yes, it support G.722
You will also need a wideband handset or headset for the feature to fully work.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps8737/product_data_sheet0900aecd806aab2b.html
