11-22-2018 02:39 PM - edited 03-17-2019 01:45 PM
Cisco document said it can support 500 CUBE sessions but considering the small number of CPS that it can support(it can only support 8 calls based on https://www.cisco.com/c/en/us/products/collateral/unified-communications/tdm-gateways/data-sheet-c78-729824.html_
IS CUBE 4331 able to handle to 100 simultaneous calls in max now and can be up to 150 in the future with this small CPS?
Does anyone use 4331 in your environment handing 100 simultaneous calls with no issues?
Cathy
11-22-2018 03:21 PM
Read here, numbers are correct. Future development of a product is NDA and you need to discuss that via your SE
11-24-2018 03:16 AM
Cathy,
You could consider running them in an active active pair. MOst service providers in Australia provide inbound load balancing. This will increase you max. simultaneous sessions
