08-08-2016 10:03 AM - edited 03-18-2019 12:04 PM
Hello Team,
In our company we have a single CUBE to SIP provider and want to introduce a second CUBE and SIP trunk. We are planning to use route group and use the SIP OPTIONS PING so if CUCM see the CUBE down, it will send the invite to the other CUBE and the call will proceed on the other SIP trunk.
One thing I'm not sure on is, if the ITSP interface goes down (say on CUBE 1), from CUCM, CUBE 1 is still up, so I guess it would send the invite there. I also guess the CUBE will send back a timeout message to CUCM. In this case, will the CUCM then send out an invite to CUBE 2? Or will the call just fail? If it won't re-send the invite again, how can we make sure we have redundancy there? Do we need to start using SLA?
Thanks for all your help
Ess
08-08-2016 10:16 AM
Hi -
This is possible. If you add something like the code I've included below on your egress dial peers in CUBE then if the CUBE is up but the SIP trunk to your service provider is down the CUBE will reject the call and CUCM will try the next CUBE in your route list / route group.
dial-peer voice 20119 voip
voice-class sip options-keepalive up-interval 12 down-interval 60 retry 3
You can see the dial peer state with the command
sh dial-peer voice sum
20119 voip up up 91[2-9]......... 1 syst ipv4:67.10.11.12 active
Les
08-08-2016 11:08 AM
What you need is CUBE HA instead of options ping. Options ping isn't the right approach for CUBE redundancy.
Please go through this doc. It has very good information about CUBE HA
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/112095-cube-hsrp-config-00.html
08-08-2016 11:41 AM
Thanks Mohammed, but due to the nature of the network setup between the two CUBEs, we can't run HSRP between them, so HA is not an option for us. In the case that we can't run HA, what would happen in my original scenario? Would the route lists / route groups on the SIP trunk make the call "failover" to the second CUBE, even though the first CUBE is up, but the ITSP is down?
08-08-2016 12:06 PM
It depends on the cause code sent from cube to CUCM and the cause of failure. Therefore, I recommended to go for CUBE HA. You can't guarantee failover with options ping.
Options ping will work only when the SIP trunk is dead such as 503 error or 480 error.
08-08-2016 12:20 PM
