does CUCME support LDAP
iantra123
Level 3
Level 3
Hi all,
From which version the LDAP is supported on Unified Com?
Does the LDAP can be used in cucme for personal and corporate directory?
Otherwise, which version of the Unified Com support LDAP integration
Antra
Jaime Valencia
Any version of CUCM supports LDAP, review the SRND under the LDAP chapter for further details of which LDAPs are supported. They change and add new version between CUCM versions so review the SRND for the version(s) you're interested.
CME does not offer any integration to an LDAP as CUCM does, you can get the directory to pull data from the LDAPs but you require to write down your custom directory script.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
t.rice.ppb
Antra,
Here (http://www.visualviewmail.com) is an inexpensive XML services application that will do exactly what you are looking for.  It will allow you to pull contact information from LDAP or Outlook/Exchange (or both).
Hi all,
Thank you for all your reply, they are very helpfull.
I've checked and I've seen the Imagicle StoneVoice Application Suite.
I'll use this tools.
regards,
Antra
